Xbox One Getting DLNA Support
Whogie
Post by Whogie » Wed Aug 13, 2014 4:58 am
http://majornelson.com/2014/08/12/kicki ... ming-soon/
MKV support too! This is surprising since Windows doesn't support it natively.
SharkHunter
Re: Xbox One Getting DLNA Support
Post by SharkHunter » Sat Aug 16, 2014 1:45 am
Being a nerd I plan to add an Xbox one to the collection asap.
Now if only sony could fix the ps4 I would be happy...
jfreiman
Post by jfreiman » Tue Aug 19, 2014 1:42 pm
I'm still on an Xbox 360 running as a Media Center - along with UMS taking up the slack....
If either of you can let me know if the Xbox One will play wtv video files (non-protected) via the new DLNA feature with our with out the assistance of UMS, that would be great to know.
Whogie
Post by Whogie » Tue Sep 09, 2014 5:32 pm
The Preview program just got the DLNA update! Unfortunately, UMS is not working with it. I'm using version 4.1.1.
Firstly, it comes up as an unknown renderer.
But more importantly, the file system isn't navigable. The only folder available is "root", and every folder inside that is "root" (and again and again.) I'm not able to locate any videos to try.
SharkHunter
Post by SharkHunter » Tue Sep 09, 2014 6:15 pm
Why am I not on the preview program?? Bill must have missed to send me an invite!!
The fact that it shows up as unknown is because it most likely hasn't a working conf file. You must create/modify that.
That said you should normally see folders (streaming is the normal problems), but I know the XBOX 360 needs some quirks to get going (there is a function isXBOX which is called to do special XBOX handling). Maybe the xbox1 needs the same special handling.
As always pls upload some logs ant we can work on the problem.
Now it would be easier for me to work on this if Bill sent me that invite. I mean I bought an xbox1 last Friday he should know that!!!
Whogie
Post by Whogie » Tue Sep 09, 2014 6:46 pm
kk, dropped a large post in the tracker thread.
I am able to manually set the profile to Xbox One. I just thought it was worth mentioning that it doesn't detect automatically.
PM me your gamertag if you want a beta invite. MS takes their sweet time with them though :/
SharkHunter
Post by SharkHunter » Tue Sep 09, 2014 6:52 pm
I'll pm that tonight :)
Do you have both a 360 and a One running in your net? If so pls disable the 360 for awhile (logs become easier to read).
Lines like
DEBUG 2014-09-08 23:29:40.961 [New I/O worker #2] DLNA changes for Xbox 360
is doing magic with the 360 maybe we should add that for the one also...
Edit.
That printout might come from the one actually as the isXBOX functions looks at the name. Maybe the one shouldn't use the 360 tricks. Easy test in the XBOXOne.conf change rendername to XOBXOne (or whatever). This will make UMS think that this isn't an XBOX but some other render...
Whogie
Post by Whogie » Tue Sep 09, 2014 6:58 pm
I have one, but it's been off. I did a "clean install" too before sending logs. I can unhook it from the network to be safe if there's anything else further you need.
Edit:
SharkHunter wrote:Edit
I'll take a look.
Whogie
Post by Whogie » Tue Sep 09, 2014 7:10 pm
(Big post, new post)
Image :)
Same problem.
You know, I've seen this root thing somewhere else:
(Networked computer. Not the one running UMS.)
New log since name change:
DEBUG 2014-09-09 00:01:55.217 [main] Reading cred.path: default: "", current: "C:\ProgramData\UMS\UMS.cred"
DEBUG 2014-09-09 00:01:55.248 [main] PID: 5428
DEBUG 2014-09-09 00:01:55.250 [main] Reading run_wizard: default: true, current: false
INFO  2014-09-09 00:01:55.250 [main] Starting Universal Media Server 4.1.1
INFO  2014-09-09 00:01:55.250 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO  2014-09-09 00:01:55.250 [main] http://www.universalmediaserver.com
INFO  2014-09-09 00:01:55.250 [main] Build: f269193bb (2014-09-06)
INFO  2014-09-09 00:01:55.251 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.7.0_67 64-bit by Oracle Corporation
INFO  2014-09-09 00:01:55.251 [main] OS: Windows 8.1 64-bit 6.3
INFO  2014-09-09 00:01:55.251 [main] Encoding: UTF-8
INFO  2014-09-09 00:01:55.255 [main] Memory: 1138 MB
INFO  2014-09-09 00:01:55.255 [main] Language: en
INFO  2014-09-09 00:01:55.256 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2014-09-09 00:01:55.256 [main] Temp directory: C:\Users\Alex\AppData\Local\Temp\universalmediaserver
INFO  2014-09-09 00:01:55.257 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2014-09-09 00:01:55.257 [main] debug.log: C:\ProgramData\UMS\debug.log
INFO  2014-09-09 00:01:55.257 [main] Profile directory: C:\ProgramData\UMS
INFO  2014-09-09 00:01:55.258 [main] Profile directory permissions: rw
INFO  2014-09-09 00:01:55.258 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2014-09-09 00:01:55.259 [main] Profile permissions: rw
INFO  2014-09-09 00:01:55.259 [main] Profile name: TERRA
INFO  2014-09-09 00:01:55.259 [main] Web conf path: C:\ProgramData\UMS\WEB.conf
INFO  2014-09-09 00:01:55.260 [main] Web conf permissions: rw
DEBUG 2014-09-09 00:01:55.470 [main] Reading minimized: default: false, current: true
DEBUG 2014-09-09 00:01:55.478 [main] Reading hide_advanced_options: default: true, current: false
DEBUG 2014-09-09 00:01:55.501 [main] Reading renderer_default: default: "", current: "Ecks Station Won"
DEBUG 2014-09-09 00:01:55.515 [main] Reading maximum_bitrate: default: "110", current: "0"
INFO  2014-09-09 00:01:55.518 [main] Loading renderer names from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2014-09-09 00:01:55.526 [main] Loading MediaInfo library
INFO  2014-09-09 00:01:55.566 [main] Loaded MediaInfoLib - v0.7.69
DEBUG 2014-09-09 00:01:55.651 [main] Reading ignored_renderers: default: "", current: "AirPlayer,Android,Android/Chromecast,Azur BD,D-Link DSM-510,DirecTV HR,Freebox HD,Freecom MusicPal,iPad / iPhone,KalemSoft Media Player,LG LA6200,LG LA644V,LG LM620,LG Smart TV Upgrader,Netgear NeoTV,Nokia N900,Onkyo TX-NR717,OPPO BDP,OPPO BDP-83,Panasonic TV,Panasonic TX-L32V10E,Panasonic VT60,Philips Aurea,Philips TV,Pioneer Kuro,PlayStation 3,Popcorn Hour,Realtek,Samsung AllShare,Samsung AllShare C/D,Samsung D7000,Samsung Mobile,Samsung SMT-G7400,Samsung WiseLink,Sharp Aquos,Showtime 3,Showtime 4,Sony Blu-ray,Sony Bravia 4500,Sony Bravia 5500,Sony Bravia BX305,Sony Bravia EX,Sony Bravia EX620,Sony Bravia HX,Sony Bravia W,Sony Bravia XBR,Sony Home Theatre System,Sony SMP-N100,Sony STR-DA5800ES,Sony Xperia Z/ZL/ZQ/Z1/Z2,Streamium,Telstra T-Box,VideoWeb TV,Vizio Smart TV,WD TV Live,WMP,XBMC,Xbox 360,Yamaha RX-A1010,Yamaha RX-V3900,Yamaha RX-V671,"
DEBUG 2014-09-09 00:01:55.888 [main] Reading folders: default: "", current: "E:\"
INFO  2014-09-09 00:01:55.889 [main] Checking shared folder: E:\
DEBUG 2014-09-09 00:01:55.915 [main] Reading audio_embed_dts_in_pcm: default: false, current: true
INFO  2014-09-09 00:01:55.998 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
DEBUG 2014-09-09 00:01:56.014 [main] Ignored AirPlayer configuration
DEBUG 2014-09-09 00:01:56.015 [main] Ignored Android configuration
DEBUG 2014-09-09 00:01:56.016 [main] Ignored Android/Chromecast configuration
DEBUG 2014-09-09 00:01:56.017 [main] Ignored KalemSoft Media Player configuration
DEBUG 2014-09-09 00:01:56.018 [main] Ignored Sony Bravia 4500 configuration
DEBUG 2014-09-09 00:01:56.019 [main] Ignored Sony Bravia 5500 configuration
DEBUG 2014-09-09 00:01:56.020 [main] Ignored Sony Bravia BX305 configuration
DEBUG 2014-09-09 00:01:56.021 [main] Ignored Sony Bravia EX configuration
DEBUG 2014-09-09 00:01:56.022 [main] Ignored Sony Bravia EX620 configuration
DEBUG 2014-09-09 00:01:56.023 [main] Ignored Sony Bravia HX configuration
DEBUG 2014-09-09 00:01:56.025 [main] Ignored Sony Bravia W configuration
DEBUG 2014-09-09 00:01:56.026 [main] Ignored Sony Bravia XBR configuration
DEBUG 2014-09-09 00:01:56.027 [main] Ignored Azur BD configuration
DEBUG 2014-09-09 00:01:56.027 [main] Ignored DirecTV HR configuration
DEBUG 2014-09-09 00:01:56.028 [main] Ignored D-Link DSM-510 configuration
DEBUG 2014-09-09 00:01:56.029 [main] Ignored Freebox HD configuration
DEBUG 2014-09-09 00:01:56.030 [main] Ignored Freecom MusicPal configuration
DEBUG 2014-09-09 00:01:56.031 [main] Ignored iPad / iPhone configuration
DEBUG 2014-09-09 00:01:56.031 [main] Ignored Pioneer Kuro configuration
DEBUG 2014-09-09 00:01:56.032 [main] Ignored LG LA6200 configuration
DEBUG 2014-09-09 00:01:56.033 [main] Ignored LG LA644V configuration
DEBUG 2014-09-09 00:01:56.034 [main] Ignored LG LM620 configuration
DEBUG 2014-09-09 00:01:56.035 [main] Ignored LG Smart TV Upgrader configuration
DEBUG 2014-09-09 00:01:56.036 [main] Ignored Nokia N900 configuration
DEBUG 2014-09-09 00:01:56.037 [main] Ignored Netgear NeoTV configuration
DEBUG 2014-09-09 00:01:56.037 [main] Ignored Onkyo TX-NR717 configuration
DEBUG 2014-09-09 00:01:56.038 [main] Ignored OPPO BDP-83 configuration
DEBUG 2014-09-09 00:01:56.039 [main] Ignored OPPO BDP configuration
DEBUG 2014-09-09 00:01:56.040 [main] Ignored Panasonic VT60 configuration
DEBUG 2014-09-09 00:01:56.041 [main] Ignored Panasonic TV configuration
DEBUG 2014-09-09 00:01:56.042 [main] Ignored Panasonic TX-L32V10E configuration
DEBUG 2014-09-09 00:01:56.043 [main] Ignored Philips Aurea configuration
DEBUG 2014-09-09 00:01:56.044 [main] Ignored Philips TV configuration
DEBUG 2014-09-09 00:01:56.045 [main] Ignored Popcorn Hour configuration
DEBUG 2014-09-09 00:01:56.047 [main] Ignored PlayStation 3 configuration
DEBUG 2014-09-09 00:01:56.047 [main] Ignored Realtek configuration
DEBUG 2014-09-09 00:01:56.049 [main] Ignored Samsung SMT-G7400 configuration
DEBUG 2014-09-09 00:01:56.050 [main] Ignored Samsung AllShare C/D configuration
DEBUG 2014-09-09 00:01:56.050 [main] Ignored Samsung D7000 configuration
DEBUG 2014-09-09 00:01:56.051 [main] Ignored Samsung AllShare configuration
DEBUG 2014-09-09 00:01:56.052 [main] Ignored Samsung Mobile configuration
DEBUG 2014-09-09 00:01:56.052 [main] Ignored Samsung WiseLink configuration
DEBUG 2014-09-09 00:01:56.053 [main] Ignored Sharp Aquos configuration
DEBUG 2014-09-09 00:01:56.054 [main] Ignored Showtime 3 configuration
DEBUG 2014-09-09 00:01:56.055 [main] Ignored Showtime 4 configuration
DEBUG 2014-09-09 00:01:56.056 [main] Ignored Sony SMP-N100 configuration
DEBUG 2014-09-09 00:01:56.057 [main] Ignored Sony Blu-ray configuration
DEBUG 2014-09-09 00:01:56.058 [main] Ignored Sony Home Theatre System configuration
DEBUG 2014-09-09 00:01:56.059 [main] Ignored Sony STR-DA5800ES configuration
DEBUG 2014-09-09 00:01:56.060 [main] Ignored Sony Xperia Z/ZL/ZQ/Z1/Z2 configuration
DEBUG 2014-09-09 00:01:56.068 [main] Ignored Streamium configuration
DEBUG 2014-09-09 00:01:56.069 [main] Ignored Telstra T-Box configuration
DEBUG 2014-09-09 00:01:56.070 [main] Ignored VideoWeb TV configuration
DEBUG 2014-09-09 00:01:56.071 [main] Ignored Vizio Smart TV configuration
DEBUG 2014-09-09 00:01:56.072 [main] Ignored WD TV Live configuration
DEBUG 2014-09-09 00:01:56.072 [main] Ignored WMP configuration
DEBUG 2014-09-09 00:01:56.073 [main] Ignored XBMC configuration
DEBUG 2014-09-09 00:01:56.074 [main] Ignored Xbox 360 configuration
DEBUG 2014-09-09 00:01:56.075 [main] Ignored Yamaha RX-A1010 configuration
DEBUG 2014-09-09 00:01:56.075 [main] Ignored Yamaha RX-V3900 configuration
DEBUG 2014-09-09 00:01:56.076 [main] Ignored Yamaha RX-V671 configuration
INFO  2014-09-09 00:01:56.076 [main] Enabled 1 configurations, listed in order of loading priority:
INFO  2014-09-09 00:01:56.076 [main] :   Ecks Station Won
INFO  2014-09-09 00:01:56.077 [main] Checking the fontconfig cache, this can take two minutes or so.
DEBUG 2014-09-09 00:01:56.080 [mplayer.exe-0] Starting C:\Program Files (x86)\Universal Media Server\win32\mplayer.exe dummy
DEBUG 2014-09-09 00:01:56.086 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO  2014-09-09 00:01:56.086 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO  2014-09-09 00:01:56.086 [main] Found VLC version 2.1.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
DEBUG 2014-09-09 00:01:56.088 [mplayer.exe-0] Attaching thread: mplayer.exe-0
INFO  2014-09-09 00:01:56.089 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2014-09-09 00:01:56.090 [main] No plugins found
DEBUG 2014-09-09 00:01:56.097 [mplayer.exe-0-2] File not found: 'dummy'
DEBUG 2014-09-09 00:01:56.097 [mplayer.exe-0-2] Failed to open dummy.
INFO  2014-09-09 00:01:56.098 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2014-09-09 00:01:56.098 [main] Registering transcoding engine: FFmpeg Audio
INFO  2014-09-09 00:01:56.100 [main] Registering transcoding engine: MEncoder
INFO  2014-09-09 00:01:56.101 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2014-09-09 00:01:56.101 [main] Registering transcoding engine: FFmpeg
DEBUG 2014-09-09 00:01:56.102 [main] Found VLC version 2.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2014-09-09 00:01:56.102 [main] Registering transcoding engine: VLC
DEBUG 2014-09-09 00:01:56.120 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, ftp, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, subfile, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms]
INFO  2014-09-09 00:01:56.120 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2014-09-09 00:01:56.120 [main] Registering transcoding engine: MEncoder Web
DEBUG 2014-09-09 00:01:56.121 [main] Found VLC version 2.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2014-09-09 00:01:56.121 [main] Registering transcoding engine: VLC Web Video
INFO  2014-09-09 00:01:56.122 [main] Registering transcoding engine: tsMuxeR
INFO  2014-09-09 00:01:56.122 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2014-09-09 00:01:56.123 [main] Found VLC version 2.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2014-09-09 00:01:56.123 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO  2014-09-09 00:01:56.124 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO  2014-09-09 00:01:56.124 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2014-09-09 00:01:56.124 [main] Registering transcoding engine: dcraw Thumbnailer
DEBUG 2014-09-09 00:01:56.141 [main] Reading alternativeffmpegpath: default: null, current: "C:\Program Files (x86)\Universal Media Server\win32\dvrms\ffmpeg_MPGMUX.exe"
DEBUG 2014-09-09 00:01:56.147 [main] Reading avisynth_script: default: "<movie>
<sub>
", current: "<movie>
<sub>"
INFO  2014-09-09 00:01:56.158 [main] Using address /192.168.1.100 found on network interface: name:eth0 (Killer e2200 Gigabit Ethernet Controller (NDIS 6.30))
INFO  2014-09-09 00:01:56.159 [main] Created socket: /192.168.1.100:5001
DEBUG 2014-09-09 00:01:56.297 [main] Sending ALIVE...
DEBUG 2014-09-09 00:01:56.304 [main] Reading uuid: default: null, current: "82e37473-7ce1-4b22-8258-3e9c7d85c075"
INFO  2014-09-09 00:01:56.304 [main] Using the following UUID configured in UMS.conf: 82e37473-7ce1-4b22-8258-3e9c7d85c075
INFO  2014-09-09 00:01:56.485 [New I/O worker #1] No IP filter specified, access granted to /192.168.1.177
INFO  2014-09-09 00:01:56.557 [main] The server is now available for renderers to find
INFO  2014-09-09 00:01:56.631 [New I/O worker #3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50
INFO  2014-09-09 00:01:56.729 [New I/O worker #4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50
INFO  2014-09-09 00:01:56.732 [New I/O worker #4] Checking shared folder: E:\
INFO  2014-09-09 00:01:56.814 [New I/O worker #5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50
INFO  2014-09-09 00:01:56.877 [New I/O worker #6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50
INFO  2014-09-09 00:01:56.990 [New I/O worker #7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DLNADOC/1.50
DEBUG 2014-09-09 00:01:58.649 [mplayer.exe-0-Cleanup] Stopping process: mplayer.exe-0
INFO  2014-09-09 00:01:59.227 [New I/O worker #8] No IP filter specified, access granted to /192.168.1.22
INFO  2014-09-09 00:01:59.229 [New I/O worker #8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DAFUPnP, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:01:59.238 [New I/O worker #8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:01:59.252 [New I/O worker #9] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.265 [New I/O worker #10] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.275 [New I/O worker #11] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.290 [New I/O worker #12] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.297 [New I/O worker #13] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.310 [New I/O worker #14] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.317 [New I/O worker #15] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.330 [New I/O worker #16] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:01:59.333 [New I/O worker #1] No IP filter specified, access granted to /192.168.1.13
INFO  2014-09-09 00:01:59.334 [New I/O worker #1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DAFUPnP, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:01:59.351 [New I/O worker #1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:01:59.375 [New I/O worker #2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.414 [New I/O worker #3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.435 [New I/O worker #4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.463 [New I/O worker #5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.478 [New I/O worker #6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.500 [New I/O worker #7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.511 [New I/O worker #8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:01:59.529 [New I/O worker #9] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
DEBUG 2014-09-09 00:02:06.556 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2014-09-09 00:02:09.069 [UPNPHelper] No IP filter specified, access granted to /192.168.1.199
INFO  2014-09-09 00:02:09.087 [New I/O worker #10] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:09.213 [New I/O worker #11] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:09.236 [New I/O worker #12] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:11.008 [New I/O worker #13] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:11.027 [New I/O worker #14] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:13.253 [New I/O worker #15] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:02:13.301 [New I/O worker #16] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.2 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
DEBUG 2014-09-09 00:02:13.705 [New I/O worker #1] HTTP User-Agent: NSPlayer/12.00.11617.0000 WMFSDK/12.00.11617.0000
DEBUG 2014-09-09 00:02:14.932 [New I/O worker #2] HTTP User-Agent: Microsoft-Windows/6.2 UPnP/1.0
DEBUG 2014-09-09 00:02:15.183 [New I/O worker #3] HTTP User-Agent: NSPlayer/12.00.11617.0000 WMFSDK/12.00.11617.0000
DEBUG 2014-09-09 00:02:26.576 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2014-09-09 00:02:31.611 [UPNPHelper] No IP filter specified, access granted to /192.168.1.100
INFO  2014-09-09 00:03:49.588 [UPNPHelper] No IP filter specified, access granted to /192.168.1.171
INFO  2014-09-09 00:05:07.485 [New I/O worker #5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DAFUPnP, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:07.493 [New I/O worker #5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:07.513 [New I/O worker #6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.531 [New I/O worker #7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.541 [New I/O worker #8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.563 [New I/O worker #9] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.572 [New I/O worker #10] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.583 [New I/O worker #11] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.591 [New I/O worker #12] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:07.600 [New I/O worker #13] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:10.314 [New I/O worker #14] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DAFUPnP, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:10.331 [New I/O worker #14] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:10.373 [New I/O worker #15] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.393 [New I/O worker #16] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.409 [New I/O worker #1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.429 [New I/O worker #2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.440 [New I/O worker #3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.451 [New I/O worker #4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.457 [New I/O worker #5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: User-Agent: Microsoft-DLNA DLNADOC/1.50
INFO  2014-09-09 00:05:10.464 [New I/O worker #6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:22.337 [New I/O worker #7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50, Cache-Control: no-cache, Pragma: no-cache, FriendlyName.DLNA.ORG: LAPNIR
INFO  2014-09-09 00:05:22.354 [New I/O worker #8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50, Cache-Control: no-cache, Pragma: no-cache, FriendlyName.DLNA.ORG: LAPNIR
INFO  2014-09-09 00:05:22.370 [New I/O worker #9] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0, Cache-Control: no-cache, Pragma: no-cache
INFO  2014-09-09 00:05:22.384 [New I/O worker #10] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50, Cache-Control: no-cache, Pragma: no-cache, FriendlyName.DLNA.ORG: LAPNIR
DEBUG 2014-09-09 00:05:22.466 [New I/O worker #11] HTTP User-Agent: NSPlayer/12.00.9600.17031 WMFSDK/12.00.9600.17031
DEBUG 2014-09-09 00:05:24.128 [New I/O worker #12] HTTP User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50
DEBUG 2014-09-09 00:05:25.390 [New I/O worker #13] HTTP User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50
DEBUG 2014-09-09 00:05:25.944 [New I/O worker #14] HTTP User-Agent: Microsoft-Windows/6.3 UPnP/1.0 Microsoft-DLNA DLNADOC/1.50
DEBUG 2014-09-09 00:05:26.595 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2014-09-09 00:07:00.371 [New I/O worker #15] HTTP User-Agent: Microsoft-Windows/6.2 UPnP/1.0
DEBUG 2014-09-09 00:07:00.388 [New I/O worker #16] HTTP User-Agent: Microsoft-Windows/6.2 UPnP/1.0
DEBUG 2014-09-09 00:07:01.399 [New I/O worker #1] HTTP User-Agent: Microsoft-Windows/6.2 UPnP/1.0
DEBUG 2014-09-09 00:07:01.420 [New I/O worker #2] HTTP User-Agent: Microsoft-Windows/6.2 UPnP/1.0
DEBUG 2014-09-09 00:08:26.615 [UPNP-AliveMessageSender] Sending ALIVE...
SharkHunter
Post by SharkHunter » Tue Sep 09, 2014 8:47 pm
Could you pls upload your log using the dbg packer? It is easier to read the zip/log in my text editor
