Xbox One Getting DLNA Support
Whogie
Re: Xbox One Getting DLNA Support
Post by Whogie » Fri Oct 03, 2014 11:36 am
Nice. I've been trying the release version. It's looking good! I don't have to turn off any renderers like WMP to get the XB1 to be seen.
I did make one minor change to the profile. Maybe for the next version :P
Supported = f:avi       v:mp4|divx           a:ac3|mp3           m:video/avi
DivX is supported, and the less transcoding the better. It's working with one of the videos I tested. Some things like mjpeg may also be supported from Jumperzz's link.
Post by SubJunk » Fri Oct 03, 2014 1:00 pm
Whogie wrote:Nice. I've been trying the release version. It's looking good! I don't have to turn off any renderers like WMP to get the XB1 to be seen.
Thanks for that, DivX support will be in the next version :)
jumperzz2014
Post by jumperzz2014 » Sat Oct 04, 2014 9:20 am
So is this new Version available to download? :)
Post by SubJunk » Sat Oct 04, 2014 3:25 pm
You can get the latest version of XboxOne.conf from here: https://raw.githubusercontent.com/Unive ... oxOne.conf which is the same as the 4.1.3 version but with DivX streaming support - the 4.1.3 version still plays it but transcodes it :)
Tezcatlipoca
Post by Tezcatlipoca » Sun Oct 05, 2014 1:43 am
Cool :)
How do I use that Xbox One conf on the OS X version of UMS?
Post by SubJunk » Sun Oct 05, 2014 12:43 pm
Find the renderers directory wherever the program files are and replace the file :)
jumperzz2014
Post by jumperzz2014 » Mon Oct 06, 2014 3:42 am
This newest XboxOne profile doesnt work good for me.
I have a 1080p/DTS Audio mkv which stucks every 2 minutes or so.
jaapie18
Post by jaapie18 » Sun Oct 12, 2014 12:27 am
Is there already a way to keep the DTS tracks?
Tezcatlipoca
Post by Tezcatlipoca » Sun Oct 12, 2014 9:55 am
SubJunk wrote:Find the renderers directory wherever the program files are and replace the file :)
I don't know where that is, though :(
I found this thread, but the location stated does not contain the renderers.
Tezcatlipoca
Post by Tezcatlipoca » Sun Oct 12, 2014 10:04 am
OK, by checking the log I found it:
"/Applications/Universal Media Server.app/Contents/Resources/Java/renderers"
It's not a location that you can browse to, as if you browse to Applications you only see the Applications - they are not like folders.
I pasted the path into Finder's Go To Folder (Shift + CMD + G) and it took me to it.
I've replaced the XboxOne.conf file and will give it a test! :)
