XBox One Won't See UMS
JimmyTheHutt
Post by JimmyTheHutt »
This seems to be the inverse of the issue most have with XBox One and UMS, where UMS won't recognize the XBox One as a renderer. My UMS sees the XBox One just fine, but my XBox One does not see the server at all. It sees the computer hosting it, but none of the served content. Does anyone have any suggestions?
Re: XBox One Won't See UMS
Hi JimmyTheHutt, we are very motivated to fix this issue. Can you please try the versions "5.0.0-b1" and "5.0.0-a1" to see which of those works, if any?
telboy1812
Post by telboy1812 »
hi there i am new here i have UMS 5.0.1 and my UMS says connect to xbox one but i do not see the UMS on my xbox one any help would be gratefully appreciated
many thanks in advance
telboy1812
**UPDATE**
i found my UMS 5.0.1
i can see the folders i added but there are no files found
what am i missing any help be gratefully received
many thanks telboy
telboy1812
**UPDATE**
all problems fixed
solution
my hard drive i used had crashed feel stupid but that is the pc for you
Thanks for updating us on this telboy1812 :)
