Channels Plugin
- AlexanderGson
Re: Channels Plugin
Getting DLNA protocol error 2110 when I go into a map where the files for a program should be. It just says "No files" where the file for the show should be while I get the DLNA error.
In the case for the logs it was for Skavlan on SVTplay, version 0.61
When I checked the logs in UMS it said something about FFMPEG. Don't know if that matters.
- ums_dbg_AlexanderGson.zip
- (61.19 KiB) Downloaded 1107 times
Re: Channels Plugin
Same thing is happening for me for the Youtube, NaviX and RTMPgui channels as well. It's possible a recent UMS update might have broke it. I'm getting the DNLA errors along with the Java errors related to FFmpeg (in the debug.log). I think Channels and the channel files themselves both need to be updated now.AlexanderGson wrote:Getting DLNA protocol error 2110 when I go into a map where the files for a program should be. It just says "No files" where the file for the show should be while I get the DLNA error.
Re: Channels Plugin
Yep, having the same thing happen, DLNA 2114 Error though every time I try to pull up a folder's contents, but folder structures are all there. This should probably be reported in issues though.
,____
||_|__\\__
|(0)___(o)|
||_|__\\__
|(0)___(o)|
Re: Channels Plugin
Yeah, hopefully Shark will have the time to work on it once he gets finished with his classes.
- SharkHunter
- Developer
Re: Channels Plugin
There was a name change in UMS 2.3.0 on a class in the code we inherit from PMS. This name change has not been propagated to Channels, and I think SubJunk is reverting the name as well. So either use UMS 2.2 or wait unitil an updated UMS sees the ligth or I release a new Channels which ever comes first.
Re: Channels Plugin
Thanks for the heads up, Shark. I think SJ will most likely fix it in the upcoming release.
Re: Channels Plugin
You are right ! Thank You. I use UMS 2.2.1 and channels work like a charm now,but... Audio play faster than video :/ I think maybe it's a frame rate problemSharkHunter wrote:There was a name change in UMS 2.3.0 on a class in the code we inherit from PMS. This name change has not been propagated to Channels, and I think SubJunk is reverting the name as well. So either use UMS 2.2 or wait unitil an updated UMS sees the ligth or I release a new Channels which ever comes first.
How can I solve this problem ?
Re: Channels Plugin
Here is a build from our latest code so you can check if it is fixed: http://www.spirton.com/uploads/UMS/UMS-channels.exe
Re: Channels Plugin
SJ,
When is the next release due to come out?
Re: Channels Plugin
Thanks SubJunk,this new UMS version has fixed some decay video/audio files that didn't work very well before but... not every files. Maybe I have to wait for the next version of UMS or perhaps there are some parameters to change in the UMS.conf ?SubJunk wrote:Here is a build from our latest code so you can check if it is fixed: http://www.spirton.com/uploads/UMS/UMS-channels.exe
Anyway Thank You one more time.
