Version 10.4.1 released
General:
This release fixes some important bugs, thanks to everyone involved in testing and fixing.
Download:
Downloads for Windows, macOS and Linux, and commands for Docker and Homebrew are available on our download page or from our official mirrors.
Changes since 10.4.0:
Operating system support:
Download:
- General:
- Fixed broken transcoding for some users
- Fixed file scanner freezing on some files with external subtitles
- Fixed support for HEVC (H.265) via tsMuxeR
- Renderers:
- Fixed detection of some Samsung 4K (UHD) TVs (thanks, jkl16!)
- Translation updates via Crowdin:
- Dutch (100%) (thanks, johnnygood!)
- German (100%) (thanks, pipin!)
- Korean (99%) (thanks, VenusGirl!)
- Norwegian (85%) (thanks, nhanssen88!)
- Spanish (100%) (thanks, Julio Alberto García!)
- Dependencies:
- Bump spotbugs-maven-plugin from 4.2.0 to 4.2.2
- Windows 7+, and limited support for Windows XP and Vista
- macOS 10.10+
- Docker
- KONTROLMASTER
- Contact:
Re: Version 10.4.1 released
Much thanks! It's working!
Hello. Thank you for the great software! I found one issue. Since version 9.8.3 the StreamSubsForTranscodedVideo option stopped working. 9.8.2 was just fine. Is it possible to fix it? Thanks!
Thanks for confirming
Thanks for letting us know. Will fix it
Hm,
10.4.1 seems to have some regressions.
Fully played marking isnt working any more for me and can't see the recently played folder or is the last one dependent on activation of the media library?
Regards,
Jens
Jens
Same for me here (using UMS with my PS3). Last version in which this feature was working well is 9.8.3. Since then, this feature is gone. Annoying, when I browse in my 2000+ movies...
I reverted back to some older 10 versions and i'm pretty sure it worked then.
But all are not working any more, so the problem could be not the version.
And all my old played markings are gone, too.
Regards,
Jens
Jens
Sorry to hear about the regression. Those features are working for me. Yes Recently Played is part of the Media Library in v10+
Can you make a thread with logs pipin?
Edit: Note, this was fixed
