Version 10.20.0 released
General:
This release improves UPnP support, improves browsing responsiveness during startup scans, speeds up loading the first folder, adds automatic ID3 tag updating via MusicBrainz, and more!
Download:
This release is available on our Patreon page for all subscribers, and will be released publicly during our next release.
Our previous version (10.19.0) is now available on our download page and from our official mirrors.
Changes since 10.19.0:
Support us:
Download:
- General:
- Added ability to update audio ID3 tags via MusicBrainz, disabled by default
- Added ability to rate/like music via API
- Added "My Albums" folder to the Media Library
- Added support for UPnP sortOrder requests when using UPnP searching
- Added dc:date UPnP attribute for renderers to optionally use
- Allow API strings to be translated
- Updated default podcasts and YouTube channels
- Fixed slow browsing of the root and web folders
- Improved responsiveness during startup scans
- Translation updates via Crowdin:
- Catalan (100%) (thanks, Toni Grau i Quellos!)
- Chinese (Traditional) (95%) (thanks, Gene Wu!)
- Danish (100%) (thanks, NCAA!)
- Finnish (100%) (thanks, Esko Gardner!)
- French (100%) (thanks, Archaos!)
- Italian (100%) (thanks, Oscar Zambotti!)
- Japanese (99%) (thanks, was0914!)
- Korean (100%) (thanks, VenusGirl!)
- Polish (100%) (thanks, Karol Szastok!)
- Portuguese (100%) (thanks, mariopinto!)
- Portuguese (Brazilian) (100%) (thanks, Mauro.A!)
- Spanish (100%) (thanks, Sergio Varela!)
- Swedish (99%) (thanks, Lorien aka the First One!)
- Turkish (100%) (thanks, Burak Yavuz!)
- Dependencies:
- Bump jna from 5.10.0 to 5.11.0
- Bump junrar from 7.4.1 to 7.5.0
- Bump metadata-extractor from 2.16.0 to 2.17.0
- Bump oshi-core from 6.1.4 to 6.1.5
- Bump spotbugs-maven-plugin from 4.5.3.0 to 4.6.0.0
Support us:
Re: Version 10.20.0 released
Thanks for the release.
German phrased are updated. Verified my crowdin mail, cause i got no notifications per mail about new strings.
And good choice, that there are now more Patreon tiers.
Regards,
Jens
Jens
Great, thanks pipin!
For some reason I can't get 10.20.0 working.
Version 10.19.0 runs without problem (serving audio FLAC files on my pc, mediaplayer Sangean WFT-3, client: BubbleUPnP).
When I upgrade 10.19.0 to 10.20.0 (no clean install), I notice that the field "Default renderer when automatic detection fails" on the General Settings tab is changed to "Unknown renderer" for some reason (and I can't select another one from the pulldown menu, this is the only entry).
Then, if I try to connect to UMS with BubbleUPnP, there's an error message:
Browse error
Reason: Current state of service prevents invoking that action. Error reading response failure message. Can't transform message payload: org.xmlpull.v1.XmlPullParserException:
Unexpected token (position: TEXT Failure: 500 [email protected]:35 in [email protected]).
The Sangean WFT-3 also couldn't connect anymore to UMS (which always worked with 10.19.0).
Next thing I did was completely remove UMS, I also deleted the folders <program files>\UMS and <programdata>\UMS. Then I did a clean install of 10.20.0, but same problem; again the "Unknown renderer" in the pulldown menu (which is the sole entry) and the error message above.
I eventually reinstalled 10.19.0 (without uninstalling 10.20.0, so overwriting the 10.20.0 installation) and everything worked fine again. Renderers can be selected again, and BubbleUPnP (and the direct connection with my Sangean) can connect to UMS.
Any idea what's wrong here?
Browse error
Can you post trace logs? You might have to make a new topic as attachments are disabled in this section.
As requested moved to the General Discussion section: viewtopic.php?f=4&t=15105
10.20.0 broken for me, shows immediate "no content found" on my samsung tv.
(10.19.0 was fine.)
(10.19.0 was fine.)
Same issue for me as both JDN165 and chickyboom unable to browse content at all using a Bravia TV and a Fire Stick, no content is found or it just times out when attempting to browse on either device. 10.19 I also confirm does not have the issue.
Thanks everyone, we have a fixed version ready to release very soon
