11.1.1.1: The Oneness
General:
This release fixes some important bugs and adds the Estonian language.
We found and fixed a bug in 11.1.1 during the release process, hence the amazing version number you see before you.
Download:
This release is available on our Patreon page for all subscribers, and will be released publicly during our next release.
Our previous version (11.1.0) is now available on our download page and from our official mirrors.
Changes since 11.1.0:
  • General:
    • Fixed failed database update for some users (#3051) (thanks, vrtlspd!)
    • Fixed Docker startup crash (#3050) (thanks, vrtlspd!)
    • Document HLS-MPEGTS-H264-AAC transcoding option
  • Translation updates via Crowdin
    • Added Estonian (23%) (thanks, Junk Knuj and Tanel K!)
  • Dependencies
    • Update dependency maven-enforcer-plugin to v3.1.0
Support us:
Paradox
Re: 11.1.1.1: The Oneness
Post by Paradox »
I unfortunately am still getting...
WARN Could not parse player id "FFMPEGHLSVIDEO"
WARN Unknown transcoding engine "ffmpeghlsvideo"
show up in log files, the same as what happened and i reported in version 11.0.0. Hopefully that can be fixed soon, otherwise the release seems to work fine. Thanks :)
lriuqs
Post by lriuqs »
Hey,
I updated from release 10.15.0 and unfortunately the server do not want to start from the services.
Through the UMS I deleted the service and installed again, but UMS still not started. I back to version 10.15.0.
