Version 5.1.1.1 for Windows is released
General:
This is a Windows-only quick fix which corrects the 32-bit MediaInfo dependency.
Changes since 5.1.1:
- General:
- Fixed MediaInfo dependency
Re: Version 5.1.1.1 for Windows is released
It keeps saying there is an update available even after I have already updated.
The version for this Update still shows as 5.1.1 hence the update notice
guess we will be seeing a 5.1.1.2 ?
Whatever was done, the showing up and listings is incredibly much better/faster for the PS/3 again !
Big thanks for that !
The fact that I completely lost DTS support since a while back, exactly when, don't know unfortunately.
Was working previously, have a pre-amp processor handling anything I throw at it, but not coming from UMS->PS/3,
only pink noise if DTS is used.
On a sidenote; for whatever it's worth,
actually managed to install UMS for java 7 while I'm running java 8. So, wrong or not, worked just fine anyway !
You have to disable any postprocessing on PS3 and also set volume on PS3 to normal & L+R channels (volume must be in central position and both channels enabled on PS3, not only left or right)
Thanks to share it.Many other can help in this site.Tanks to provide in this site.
