Version 2.5.2 is released
General:
This release fixes a startup error for Java 6 users, fixes media caching and more
Changes since 2.5.1:
  • General:
    • Offer to automatically update Java on Windows from 6 to 7
    • Fixed library updating with cache enabled
    • Made detection of network speed more accurate (thanks, ExSport!)
    • Library scanning interface improvements
    • Set a higher maximum memory by default via the Windows installer for computers with 4GB+ of RAM
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
uman2k for building the OS X version
uman2k
Re: Version 2.5.2 is released
Post by uman2k »
Here is the DMG for Mac OS X users.
Cheers!
EDIT: Updated icon
sujayt
Post by sujayt »
Awesome, thanks so much for getting this done, uman2k! Works great.
Question for SubJunk, been waiting for ffmpeg muxing, as tsmuxer has had a bug on OSX for a long time with MKVs. Video muxing seems to work fine, except not with DTS audio, only when converting to Dolby Digital. Does patched DTS audio remuxed with AVC video only work with tsMuxer, and not ffmpeg?
(OS X 10.8.3, streaming to PS3 and HDMI receiver)
Optimus_prime
Post by Optimus_prime »
nice work uman2k, i've uploaded it to sourceforge
sujayt wrote:Awesome, thanks so much for getting this done, uman2k! Works great.
Hi sujayt, yes unfortunately it isn't possible to remux DTS with only FFmpeg, an external program needs to be used. In our case we use tsMuxeR. You can try lowering the CPU threads if you want and see if that makes a difference, it seems like the kind of bug that would be affected by multithreading. On the transcoding settings tab set CPU threads to 1 or 2 and see what happens
uman2k wrote:Here is the DMG for Mac OS X users.
I've uploaded the release now and am updating the first post, thanks!
sujayt
Post by sujayt »
SubJunk wrote:Hi sujayt, yes unfortunately it isn't possible to remux DTS with only FFmpeg, an external program needs to be used. In our case we use tsMuxeR. You can try lowering the CPU threads if you want and see if that makes a difference, it seems like the kind of bug that would be affected by multithreading. On the transcoding settings tab set CPU threads to 1 or 2 and see what happens
Thanks for the insight, I'll experiment with it.
uman2k
Post by uman2k »
Optimus_prime wrote:nice work uman2k, i've uploaded it to sourceforge
Thanks to you and Subjunk, in fact all credits are for him.
I had updated the package to add the icon to the DMG package as well as the image disk icon.
Optimus_prime
uman2k wrote:Thanks to you and Subjunk, in fact all credits are for him.
As always Subjunk deserves every bit of credit we can give him (I'd never take any anyway, but don't forget the other developers). Great to see we have OS-X builds up and running. I've finally built my Mac (OS-X 10.8.3) so i'm hoping to help out with these builds when i can. But i would like to see some Java 7 builds happening, so i will try to get one up in the beta section soonish
Sunwind
Post by Sunwind »
I was wondering why my UMS was updating when I updated it manually like 2 days ago. nice job getting the fixes and improvements out there fast.
