[Solved] No thumbnails and zoomed video on Sony KDL-40EX521
Re: No thumbnails and zoomed video on Sony KDL-40EX521
Ok, I'll do it in 1 hour... Can you please tell me what does that command do? Can I put multiple versions of the code for each video resolution I have? For example:
Do I have to repeat the video resolution 2 times, for scale and pad?
Thanks and sorry for so many questions...
OverrideVideoFilter=scale=720:404,setdar=4/3,pad=720:404
OverrideVideoFilter=scale=1280:720,setdar=4/3,pad=1280:720
- SharkHunter
- Developer
Nope you can only set one at a time.
ANd only one line with both scale and pad
Understood... Unfortunately, no results
What resolution do I have to put in the code? The resolution of the video or the resolution of the TV, like 1920x1080?
I really hope it's not a setting on my Bravia, but I've really analyzed all the settings without any results...
this solution also solves my problem viewtopic.php?f=9&t=1315,SharkHunter wrote:Hi,
For thumbs addto the render config file. I think your render config should be "BraviaEX.conf". If it works come back and I'll it to the repo.Code: Select all
ThumbnailAsResource=true
thank you
- SharkHunter
- Developer
It's the resoultion of the TV. If it doesn't work fiddeling with the params then I'm out of ideas for that one.ciarals wrote:Understood... Unfortunately, no results
This one will go into all Bravia conf files since it seems Bravia needs that.nocciola82 wrote:this solution also solves my problem viewtopic.php?f=9&t=1315,SharkHunter wrote:Hi,
thank you
And as I was fearing, it wasn't a UMS problem, but a Sony hidden configuration -.-
If also other users as me are having the zoomed/enlarged picture "problem", please be sure to select [+1] in the "Display Area" settings located inside "Screen" settings: http://docs.esupport.sony.com/imanual/N ... pc_uc.html
So, to sum up, zoomed video problem is solved and thumbanils problem is solved by using this code in the conf file of the Bravia:
SharkHunter, one last question for you: thumbnails seem to be in lower resolution that when are displayed on PS3. Is there a reason for this?
