Transcoding and subtitles
AuthenticM
Post by AuthenticM »
I've been having an issue for several releases. It's still the case with 6.7.1.
Basically, UMS cannot transcode a file and display subtitles at the same time.
I boot the app on my PS4, go where the file is on my laptop and select the "transcode" directory. I then get multiple options, such as transcoding the file with FFmpeg, transcoding the file with FFmpeg and display subtitles (it's a .mkv file containing subtitles), a second (but different) option to transcode the file and display subtitles, and the same three options for MEncoder. There's also the "no transcoding" option.
The only three options that work are "no transcoding" (though the PS4 cannot play the audio in this scenario, so I don't choose it), transcode with FFmpeg sans subtitles, and transcode with MEncoder sans subtitles. The options for transcoding with subtitles lead the PS4 to display "cannot read file".
Sami32
Re: Transcoding and subtitles
Post by Sami32 »
did the UMS 6.5.3 version solve your issue ?
https://sourceforge.net/projects/unimed ... g/download
This subtitle issue was introduced after that version and need to be fixed.
AuthenticM
It does the same thing, sadly. Although this time the option "MEncoder" (sans subtitles) did not work. Though maybe it also didn't work previously and I simply forget. But there aren't any option with subtitles that work.
