UMS 3.0.0 won't play any mkv's without stuttering on PS3
Cidious
Post by Cidious »
I just installed the latest stable version of UMS (clean install). I updated from 2.6.5. This version worked fine except for A/V syncing of a Dolby Digital stream.So I wanted to upgrade badly because I have tried about everything to get the sync right without any luck.
But now my PS3 won't play any MKV's anymore. It just opens and you can hear a few seconds of the sound track and see a couple of video frames and then freezes. I run the same encoding settings I did on version 2.6.5 but I have also tried another clean installe with out of the box settings. No luck yet.
Any ideas?
sapsa
Re: UMS 3.0.0 won't play any mkv's without stuttering on PS3
Post by sapsa »
I had few problems with some files because there were badly encoded.
Best option is to pass debug.log here (delete it before you try, start ums, play that faulty file on ps3, wait till fail, close ums save debug.log)
Other solution could be that your cpu is not so fast.
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
Cidious
Post by Cidious »
debug.log: http://pastebin.com/wFeegP2a
The thing is. Everything played fine on version 2.6.5. I am talking about the exact same .mkv files.
I installed PMS 1.90.1 and everything also plays fine. So something has to be wrong with the new UMS 3.0.0
Optimus_prime
Post by Optimus_prime »
I might bump this to Subjunk and see what he can see. Hope we find the issue if there is one
It looks like a pretty rare release of that movie, I would suggest trying more popular releases in the future, for that movie there's the PublicHD release or the EVO release, lots of high quality groups released that movie in 1080p quality but I can't find any info on that file.
I suspect what is happening is that in 2.6.5 the file was being transcoded which made it play well, but in 3.0.0 it is being muxed but something about the file is incompatible with the PS3.
Can you please paste the MediaInfo of the file? Maybe it will give clues as to why the PS3 doesn't like it.
Cidious
Post by Cidious »
Thnx for your response. The mkv files are comming from a specific community which releases its own movies. Which I never had problems with.
Here is the mediainfo file: http://pastebin.com/6DmCGTqW
Transcoding the file does indeed work with 3.0.0 and 3.1.0. But liked the simplicity of 2.6.5 that everything played automatically with one click.
I agree that it's a problem to have to transcode instead of one click. Are there any smaller files that also have the problem? Or are you able to upload or give me a link to that file?
Wolfgan
Post by Wolfgan »
I read many threads where non tech users comment on videos skipping, or poor quality or rejected content and probably it's all related to transcoding of unsupported formats. Wouldn't be a good idea to make the file type detected more explicit in the main window log for easier auto troubleshooting?
ie: Serving MyVideofile.mp4 [container:mp4, vcodec:avc, acodec:mp3, subs:no] without transcoding
or: Serving MyVideofile.mkv [container:mkv, vcodec:avc, acodec:mp3, subs:no] transcoded to [container:m2ts, vcodec:avc, acodec:LPCM, subs:ccaption] by Mencoder
Maybe it may also be integrated to the presented #Transcode folder name as well (ie MyVideofile.mkv [mkv,avc,mp3] ) so its also visible from the Renderer interface.
How does it sound? Wolf.
@Wolfgan: I'm not sure, since we have that info in the debug log already so I think the Logs window is nice how it just displays a simple history now. I'm not sure though there are lots of ways to go on that.
@Cidious: Looking at the MediaInfo I see that it is listed as variable frame rate, which must mean there is a problem with the way the file was put together because the movie wouldn't be VFR. That may be what's causing problems, but I'll know more if I can get a copy of the file or another file that has the same problem.
