startup errors windows 10 64bit install
CharlieBisbee
Post by CharlieBisbee »
Just trying now to get a clean start up. Looking at debug log. This is after a clean install
Error cannot find ffmpeg -- well thats because the ffmpeg64 is the installed version. This was fixed by editing the UMS.conf file (in programdata\ums) to include
ffmpeg_path = C:\\Program Files (x86)\\Universal Media Server\\win32\\ffmpeg64.exe
now it finds ffmpeg. Seems the installer for 64 bit should know and fix this.
NEXT I cannot solve
[main] Error loading MediaInfo library: Unable to load library 'mediainfo': Native library (win32-x86/mediainfo.dll) not found in resource path ([file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/ums.jar])
MediaInfo64.dll is in the UMS program directory. There is no entry similar to ffmpeg entry in the conf file so cannot set the path. I tried
//renaming the MediaInfo64.dll to MediaInfo.dll with no luck. I tried creating a win32-x86 dir and puting it there both with and without 64. Nothing works.
I have looked in ums.jar and it does not seem to be in there.
So how do I get UMS to find (and use) the installed MediaInfo64.dll ?????
Charlie Bisbee
