V8 and Youtube?
V8 and Youtube?
HI
I just downloaded v8 and want to use it as a frontend for Youtube.So I added couple Web content but I am not seeing any videos? I see some channels added but they are shown as just numbers instead of the actual channel name.
I am wondering if Youtube supposed to work? If so can someone please advise me with the right settings and right Youtube url format?
Here is a portion of the log, seems parsing errors. Bug?
thanks
ERROR 16:34:31.234 [DLNAResource resolver thread 22-2] Error in parsing stream: https://www.youtube.com/feeds/videos.xml?user=FZDSCHOOL
at net.pms.network.HTTPResource.downloadAndSendBinary(HTTPResource.java:222)
at net.pms.network.HTTPResource.downloadAndSendBinary(HTTPResource.java:196)
at net.pms.dlna.Feed.parse(Feed.java:108)
at net.pms.dlna.Feed.resolveOnce(Feed.java:94)
at net.pms.dlna.DLNAResource.resolve(DLNAResource.java:1576)
at net.pms.dlna.DLNAResource.syncResolve(DLNAResource.java:1561)
at net.pms.dlna.DLNAResource.run(DLNAResource.java:1358)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
thanks
Re: V8 and Youtube?
No one uses this with Youtube?
Re: V8 and Youtube?
I've never done it at least. I don't quite see the point either, you can access youtube directly form computers, phones, many TV's etc. Google does everything it can to "sabotage" access from outside their own delivery system, because they want to force-feed you a lot of ads. I wouldn't want to spend my time with this cat-and-mouse game to get access to what is on youtube.
Re: V8 and Youtube?
Thanks for the reply. THis whole point of you can access youtube anywhere is not a good analogy in this case because we are talking about being able to cast youtube streams to any device we want using a server like this. At least my use case has nothing to do with not being able to access youtube with other ways, I just would like to be able to cast streasm to some of the players I have here.
In any case I was just wondering.
