UMS wont start
UMS wont start
Hi im having similar issue as OP of this thread: https://www.universalmediaserver.com/fo ... =9&t=13457
Javaw.exe starts then immediatly closes
Followed similar steps
debug.log wont create
Uninstall/reinstall/updated Java
Uninstall/reinstall Ums
Deleted UMS/Universal media folder appdata/program files folders
Checked for older version of ums as i think i used to run it years ago : didnt find any
Ran same cmd line command that op did to maybe get some help
Trying to figure out why UMS wont start.
C:\Program Files (x86)\Universal Media Server>java -Xmx768M -Djava.net.preferIPv
4Stack=true -Dfile.encoding=UTF-8 -classpath update.jar;ums.jar net.pms.PMS
Exception in thread "main" java.lang.ExceptionInInitializerError
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:6
05)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:5
65)
at net.pms.PMS.main(PMS.java:1016)
Caused by: java.nio.file.InvalidPathException: Trailing char < > at index 16: C:
\Program Files
at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
at sun.nio.fs.WindowsPath.parse(Unknown Source)
at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
at java.nio.file.Paths.get(Unknown Source)
at net.pms.util.FileUtil.getOSPath(FileUtil.java:1904)
at net.pms.util.FileUtil.findInOSPath(FileUtil.java:1957)
at net.pms.util.FileUtil.findExecutableInOSPath(FileUtil.java:1922)
at net.pms.configuration.WindowsProgramPaths.<init>(WindowsProgramPaths.
java:110)
at net.pms.configuration.PlatformProgramPaths.<clinit>(PlatformProgramPa
ths.java:147)
... 3 more
Re: UMS wont start
It seems reasonably clear that your problem is with your PATH as well. If you post the content of your PATH, my guess is that it's easy to spot the problem. To list the PATH content, simply run from a cmd.exe shell:
echo %path%
Re: UMS wont start
Think i got it fixed so dumbNadahar wrote: ↑Wed Apr 17, 2019 3:29 pm It seems reasonably clear that your problem is with your PATH as well. If you post the content of your PATH, my guess is that it's easy to spot the problem. To list the PATH content, simply run from a cmd.exe shell:Code: Select all
echo %path%
C:\Program Files;
was C:\Program Files ;
Changed that and program starts up
Re: UMS wont start
Sorry for the double post but ran into a issue with ums again.
Socan sttream most things just fine but anytime i try to stream .flac on ps4 it has to transcode to send it but no file sounds proper. Sounds weird and garbled.
but if i select another song for a brief second before it startsthe next track it sounds proper
