Issues with Server working Over WiFi
My Router : Linksys E3000 w/DD-WRT v24-sp2 (03/25/13) big - build 21061
Issue with Consoles not seeing over the WiFi. I was trying it out with my XBox 360 on hooked to a LAN but I tired it over WiFi and it will see the server. I restarted the Server then it was able to see it but couldn't connect to the list. UPNP it enabled and disabled the firewall on my home server.
- Router WIFI Settings.jpg (428.4 KiB) Viewed 2773 times
- Router Firewall Settings.jpg (307.96 KiB) Viewed 2773 times
Re: Issues with Server working Over WiFi
The above doesn't make much sense to me. Can you try to explain this is a bit more detail?Markitzero123 wrote: ↑Sun Nov 17, 2019 5:04 pm Issue with Consoles not seeing over the WiFi. I was trying it out with my XBox 360 on hooked to a LAN but I tired it over WiFi and it will see the server. I restarted the Server then it was able to see it but couldn't connect to the list. UPNP it enabled and disabled the firewall on my home server.
