UMS not working after windows upgrade
Hello!
Recently i have switched from Win 8.1 to Win10.After the update the server is no longer visible to my smart TV(samsung).
What am i doing wrong?Please help.
Re: UMS not working after windows upgrade
can you be more specific?
There's loads and loads of threads about this on this forum. Try to disable Windows Firewall/Defender and see if that "solves it". I'm pretty confident it will. If it works, there are several ways to solve it, for example by manually creating the necessary firewall rules.
Fuck i'm high.
i have played around with the firewall rules (attached screenshots). Idk what else to do,please help.
- Screenshot_3.png (82.77 KiB) Viewed 6578 times
- Screenshot_2.png (24.78 KiB) Viewed 6578 times
- Screenshot_1.png (9.26 KiB) Viewed 6578 times
I'm not sure what you have and haven't done, but it looks like quite a mess. I would uninstall UMS and Java, and remove any rules belonging to either after uninstallation - and then install from scratch.
