HOWTO - Device Spy - What your Renderer can really use
Taken from a separate thread; intended to be a resource thread.
What the device supports you can do this:
1. Install Intel UPnP tools - LINK
2. run Device Spy
3. It should list all your UPnP device and among them your device (eg TV, console, etc)
4. Expand the device's tree and find service: urn:upnp-org:serviceId:ConnectionManager:1
5. Expand that and double click on GetProtocolInfo(...).
6. And you need to use the the result in field Sink.
Or Alternatively you may find you device here via a search for it's supported features via DLNA Product Search
2. run Device Spy
Universal Media Server Wiki!
