Web authentication
Bezalel79
Web authentication
Post by Bezalel79 »
Hi Everybody.
I'd like to enable web authentication.
I've found this post:
https://universalmediaserver.com/forum/ ... hp?t=13490
and so I add this lines:
UMS.cred
web.server = test,test
UMS.conf
web_authenticate = true
But don't work, can you help me?
I use UMS 9.3.0 on Windows 10
Re: Web authentication
It has probably been broken at some stage without getting noticed, since I don't think very many people use this. Try earlier versions, I know it works in 6.x.
If it has been broken along the way it would be good to know when that was, Bezalel79. Please let us know if it works in v6 first
Bezalel79
Post by Bezalel79 »
I understand that at least until version 7.8.0 it worked
Bezalel79
Post by Bezalel79 »
With version 9.4.0 now it works.
Thank you very much!!!
lcfx_lain
Post by lcfx_lain »
Hi! I'm using UMS on Windows, I can't find the first file mentioned here:
UMS.cred
Changing only this is not enough (Web interface ask for user/password but User=test and Pass=test didn't work)
UMS.conf
I need some help here, thanks
lcfx_lain
Post by lcfx_lain »
Ok, I figured it out
C:\ProgramData\UMS < This is where those files are (The folder is hidden).
The UMS folder should not be hidden. The "ProgramData" might be hidden though, depending on your Windows settings.
