UMS disconnected when entering some folders
My renderer is Panasonic P46ST32C, and the version of UMS is 3.1.2.1 and 3.2.1, all clean install. UMS shows in my TV, but when I entered some specific folders, the UMS will be disconnected. I attached the debug log and some java error files. The folder I try to enter is D:\Video\Movie, which containing about 84 sub folders.
Re: UMS disconnected when entering some folders
It's fine when I roll back to 3.1.0
It might be caused by the MediaInfo update. Can you please replace MediaInfo.dll and MediaInfo64.dll in the "D:\Program Files (x86)\Universal Media Server" folder with the following files to see if that fixes it?
MediaInfo.dll
MediaInfo64.dll
MediaInfo.dll
MediaInfo64.dll
I cannot download the files you provided (I cannot access googlecode in China!), but I replace those files with those in version 3.1.0, and it works!
So I can confirm this issue.
i tried this and cannot because i'm told i don't have the correct permissions. and i'm an administrator. the non 64.dll worked.SubJunk wrote:It might be caused by the MediaInfo update. Can you please replace MediaInfo.dll and MediaInfo64.dll in the "D:\Program Files (x86)\Universal Media Server" folder with the following files to see if that fixes it?
MediaInfo.dll
MediaInfo64.dll
OK cool, the fix will be in the next version. Thanks for testing!
