Annoying bug
Annoying bug
I've identified a minor bug, but haven't been able to work around it. Specifically, there is an exception being thrown in the RemoteThumbHandler, which isn't properly handled, and consequently loading of a directory of music files never finishes loading, and the browser window just keeps 'spinning". I see the exception in the syslog:
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.960 [pool-2-thread-22] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.960 [pool-2-thread-24] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.960 [pool-2-thread-23] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.960 [pool-2-thread-25] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.993 [pool-2-thread-28] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Nov 28 20:08:29 saturn UMS.sh[1776]: ERROR 20:08:29.993 [pool-2-thread-26] Unexpected error in RemoteThumbHandler.handle(): UUID string too large
Initially, i thought that maybe my JDK was too old, since the UUID:FromString() changed somewhere between JDK 8 and 9, but I upgraded to JDK 11, and the problem persists, the other thing that I noticed is that the bug doesn't manifest itself all the time, only in some subdirectories, but I've been able to identify the cause. Any suggestions?
Re: Annoying bug
What we can suggest without seeing the .log?
Re: Annoying bug
The log entries that I put in my original post are the only things that is logged when the problem occurs. There is nothing else out of the ordinary in log. I even found the pertinent Java code that generates the exception, so I guess what I'm saying is that I already know what the problem is, I was just trying to avoid having to set up the build environment to fix it myself. After all, since I'm seeing the problem with a regularity, it must affect other users as well, so I figured that the developers might want to know about it.
Re: Annoying bug
Here is the log. It doesn't give any more details than what I already described in my previous messages, but here you go....
- umslog.zip
- (4.21 KiB) Downloaded 548 times
Re: Annoying bug
That log is not much use. Please follow the section above in red on how to create TRACE logs.
Re: Annoying bug
here you go...
- ums_dbg_2021-02-07-20-24.zip
- (4.33 MiB) Downloaded 472 times
