LG CX DTS Problem
wurstpistole
Re: LG CX DTS Problem
Post by wurstpistole »
I got my new LG CX9 today and want to chip in on this.
So essentially, what I did first is click my renderer in UMS, open the config file and delete the three instances of "dts" under
# Supported video formats:
Then I went into UMS general settings, audio settings and unchecked both Encoded audio passthrough for DTS and AC3 and keep DTS tracks.
That seemed to work for standard DTS. Not for DTS HD though, those files still play no audio in standard transcoding. Any way to get past that?
FrancescoV140681
Post by FrancescoV140681 »
Yes that works but when you see something in HDR the television turned of HDR and the picture is very bad
topminttwo
Post by topminttwo »
I am ready to make this. I can help to make a configuration for the LG CX TV's or for the Webos TV's without DTS Support.
FrancescoV140681
O.k. what do you need herefor?
