Mencoder doesn't work with avi -- fresh install
I am getting the errors in the log snippet below when using mencoder. Setting ffmpeg to a higher priority results in successful transcoding. I'm on Win 7 x64 with a fresh install of UMS. Any idea why this may be happening? I have successfully played a few mkv files.
DEBUG 2014-02-26 15:30:27.193 [New I/O worker #3] Starting transcode/remux of Galapagos - S01E01 - Born of Fire.avi with media info: container: null, bitrate: 0, size: 2298023936, video codec: null, duration: null, width: 0, height: 0, frame rate: null, thumb size : 892, muxing mode: null, mime type: video/mpeg
DEBUG 2014-02-26 15:30:27.201 [New I/O worker #3] Caught exception
at net.pms.encoders.MEncoderVideo.launchTranscode(MEncoderVideo.java:1063) ~[ums.jar:3.4.2]
at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:2391) ~[ums.jar:3.4.2]
at net.pms.network.RequestV2.answer(RequestV2.java:350) ~[ums.jar:3.4.2]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:292) ~[ums.jar:3.4.2]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:250) ~[ums.jar:3.4.2]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) ~[ums.jar:3.4.2]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) ~[ums.jar:3.4.2]
at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) ~[ums.jar:3.4.2]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) ~[ums.jar:3.4.2]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:109) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:312) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:90) ~[ums.jar:3.4.2]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) ~[ums.jar:3.4.2]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_51]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_51]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_51]
DEBUG 2014-02-26 15:30:27.203 [New I/O worker #4] Starting transcode/remux of Galapagos - S01E01 - Born of Fire.avi with media info: container: null, bitrate: 0, size: 2298023936, video codec: null, duration: null, width: 0, height: 0, frame rate: null, thumb size : 892, muxing mode: null, mime type: video/mpeg
DEBUG 2014-02-26 15:30:27.204 [New I/O worker #4] Caught exception
DEBUG 2014-02-26 15:30:32.051 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-144
DEBUG 2014-02-26 15:30:32.052 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-143
DEBUG 2014-02-26 15:30:32.052 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-145
DEBUG 2014-02-26 15:30:32.642 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-149
DEBUG 2014-02-26 15:30:32.642 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-150
DEBUG 2014-02-26 15:30:32.644 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-151
DEBUG 2014-02-26 15:30:33.068 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-155
DEBUG 2014-02-26 15:30:33.069 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-156
DEBUG 2014-02-26 15:30:33.070 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-157
DEBUG 2014-02-26 15:30:33.474 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-161
DEBUG 2014-02-26 15:30:33.474 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-162
DEBUG 2014-02-26 15:30:33.475 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-163
DEBUG 2014-02-26 15:30:33.840 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-167
DEBUG 2014-02-26 15:30:33.902 [FFmpeg Thumbnail Failsafe] Stopping process: ffmpeg.exe-168
