UMS won't play AVC-AAC movie wrapped in MKV
I was playing a series seasons 1 - 6 without any problems, but during season 7 at episode 5 suddenly UMS says all files are corrupt.
The files play just fine on my PC with both MPC-HC and VLC players, so I guess the problem is in UMS or (one of) the used codecs.
Besides MEncoder no other codec will even find a playable file.
I've attached the trace log, which reports something may be wrong with MEncoder. (I think)
I'll gladly provide more info if needed.
Regards.
EDIT REASON: Removed file since no-one bothered with it.
Regards.
