All ver after 3.3 fails networked media
emerson8
Post by emerson8 »
Now, did a zip-debug and uploaded it.
I am getting "filexxx.xxx could not be parsed. It will be hidden" for every single file I have.
Previously seen this maybe on some file sometimes, but now, it states that for all = only directories visible, nothing in them.
Tried probably each release post-3.3
(73.93 KiB) Downloaded 427 times
emerson8
Re: All ver after 3.3 fails networked media
Post by emerson8 »
additional info;
This error occurs for every file in the log.
Can also be confirmed by the fact that no files are seen from either;
Oppo, PS/3, Sony-TV or LG-TV.
And, only change is the "clean install" of anything above 3.3 = no files
Re-do install with 3.3 or older = all ok again !
emerson8
Post by emerson8 »
Anyone ?
Hope the debug.zip was done correct. Can't see something "on this side" that causes it,
simply anything after 3.3 stops working, so there must be some change.
emerson8
Post by emerson8 »
well,, trying again....
Do think the debug was done correctly and any measurements to make sure exactly how/when the error is reproduced has been done.
Clean install, time and time again. Same issue still, anything above 3.3 disables all files stored on windows mapped shares.
