Files seen, folders not seen on LG SmarTV
Just installed UMS. Am familiar with GUI as I've used PMS for years.
TV is a 2014 LG SmarTV (LG 65UB9500)
When I go to the TV's Smart Share to stream, I can see the files on my computer, but no folders that I've organized them into. It's great having files there, but is there a feature where I can see the file structure on my computer to navigate on my TV? I have 3 HDDs sorted, so a file tree would be helpful.
I installed Plex and ran it the same as UMS, and I did get folders, which leads me to believe it's a UMS feature I missed (although my file structure is visible when running UMS to my PopcornHour). I have not manually configured the .conf, but if I need to post it for help I'll do that no problem.
I appreciate any help you can provide.
