3gp files playing at double speed?
Using UMS 5.2.3 and the Panasonic Viera renderer on a TX-P50G20BA.
So far everything has been working great. Tried playing a *.3gp media file and it seems to be playing at double speed. Same file type plays OK with Serviio and Mezzmo. Any ideas how I could fix this?
EDIT: Trace log only says file started playing and then file stopped playing. Let me know if you still need it. Mediainfo on file below.
General
Complete name : F:\Media\My Pictures\VID 00002-20110713-1703.3GP
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 1.62 MiB
Duration : 16s 789ms
Overall bit rate mode : Constant
Overall bit rate : 811 Kbps
Encoded date : UTC 2011-07-13 16:04:19
Tagged date : UTC 2011-07-13 16:04:19
Video
Format : MPEG-4 Visual
Format profile : Simple@L0
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Bit rate mode : Constant
Bit rate : 794 Kbps
Nominal bit rate : 26.7 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 13.640 fps
Minimum frame rate : 9.709 fps
Maximum frame rate : 14.706 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.758
Stream size : 1.59 MiB (98%)
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Duration : 16s 740ms
Bit rate : 12.8 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 26.2 KiB (2%)
Writing library : rimm
Re: 3gp files playing at double speed?
Anyone?
Debug files attached.
- (94.37 KiB) Downloaded 418 times
Another piece of the puzzle. The above is using FFmpeg as the Video Files Engine i.e. both video and audio sped up.
When using MEncoder instead, the audio is normal but the video is still sped up (debug files attached).
Appreciate any help.
- (88.49 KiB) Downloaded 417 times
Bump.
Anyone???
Anyone???
