[SOLVED]Sony BDP-S590 - 2012 US Models ONLY
Ranger187
Contact:
Post by Ranger187 »
I've since updated this original post to have all the relevant information which I will continuously update if I find better settings.
UPDATE HERE IS THE FINAL CHANGES MADE TO MAKE THE SONY BDP-S590 STREAM NEARLY EVERYTHING TOSSED TO IT
# Profile for Sony Blu-ray Players (2010 Bravia Internet Video-enabled models).
RendererName=Sony Blu-ray
# Sony Bluray uses the following headers:
# User-Agent: UPnP/1.0
# X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0";
# X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player";
# User-Agent: UPnP/1.0 DLNADOC/1.50
# The User-Agent strings are too generic to match
#UserAgentSearch=
UserAgentAdditionalHeader=X-AV-Client-Info
UserAgentAdditionalHeaderSearch=(cn="Sony Corporation"; mn="Blu-ray Disc Player")
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGTSAC3
TranscodeAudio=LPCM
DefaultVBVBufSize=true
MuxH264ToMpegTS=false
MuxDTSToMpeg=false
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=0
MaxVideoHeight=0
H264Level41Limited=true
#MimeTypesChanges=
DLNALocalizationRequired=true
#TranscodeExtensions=
#StreamExtensions=
MediaParserV2_ThumbnailGeneration=false
# For Sony Bluray players and Bravia TVs
ForceJPGThumbnails=true
ChunkedTransfer=true
# Specs below taken from http://www.sony.co.uk/product/blu-ray-disc-player/bdp-s370#pageType=TechnicalSpecs
# then fine-tuned by lengthy trial and error since so much of that advertised spec is inaccurate.
# US models don't support video/divx mime type but European and Canadian models do.
# Subtitles in mkv files are only displayed if mime type is video/divx.
# Vob subtitles are not supported.
# See also http://forum.serviio.org/viewtopic.php?f=11&t=2004 for more DLNA-related info on these players.
MediaInfo=true
# Supported video formats:
Supported = f:mpegps|mpegts   v:mpeg1|mpeg2     a:ac3|dts|lpcm|mpa|mp3                    m:video/mpeg
Supported = f:mpegts          v:h264|vc1        a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/vnd.dlna.mpeg-tts
Supported = f:mp4|m4v         v:mp4|h264        a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/mp4
Supported = f:wmv             v:wmv|vc1         a:wma                                     m:video/mp4
######### NON-US MODELS: CHANGE THE FOLLOWING 2 MIME-TYPES TO m:video/divx
Supported = f:avi        v:mp4        a:ac3|lpcm|mpa|mp3                        m:video/mp4
Supported = f:mkv             v:mp4|h264   a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/x-matroska
# Supported audio formats:
Supported = f:wma    n:2   m:audio/mpeg
Supported = f:mp3    n:2   m:audio/mpeg
Supported = f:lpcm   n:2   m:audio/L16   s:48000
# Supported image formats:
Supported = f:jpg   m:image/jpeg
THESE ARE THE ONLY LINES CHANGED IN \Renders\SonyBluray.conf:
Change this line:
Supported = f:avi|divx        v:divx|mp4        a:ac3|lpcm|mpa|mp3                        m:video/mpeg
To this:
Change this line:
Supported = f:mp4|m4v         v:mp4|h264        a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/mpeg
To this:
Change this line:
Supported = f:mkv             v:mp4|divx|h264   a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3   m:video/x-matroska
To this:
Below is the final file with changes.
SonyBluray.conf
2013-03-31-5:15pm Edit
(3.01 KiB) Downloaded 1267 times
Ranger187
Contact:
Re: Sony BDP-S590
Post by Ranger187 »
Changing:
To:
Supported = f:avi|divx   v:divx|mp4   a:ac3|lpcm|mpa|mp3   m:video/mp4
Might have helped....
I do know that Twonky marks all the files as "AVI", whereas UMS marks the same files as mpeg, so is there a way to force mpeg,mp4,m2ts,mkv to transcode as avi?
Ranger187
Contact:
Re: Sony BDP-S590
Post by Ranger187 »
Mental note:
AVI's play if they are xvid. If they are .avi's that are divx it fails.
How would I go about forcing UMS to transcode .avi's that have divx in the media info as an avi instead? (mpeg)....
Ranger187
Contact:
Re: Sony BDP-S590
Post by Ranger187 »
Ranger187
Contact:
Re: Sony BDP-S590
Post by Ranger187 »
So far, this update has alleviated almost all my issues. We are still working on it on the PMS site (oddly I'm getting more support there!)....
All that was changed was the avi and mp4 lines. I bolded it. NOTHING IN UMS thus far needs changed.
Here's my conf for SonyBluray.conf
#UserAgentSearch=
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeAudio=LPCM
MuxDTSToMpeg=false
MuxLPCMToMpeg=false
MaxVideoWidth=0
MaxVideoHeight=0
#MimeTypesChanges=
#StreamExtensions=
MediaInfo=true
Ranger187
Contact:
Re: Sony BDP-S590
Post by Ranger187 »
Updated the first post. This solves the Sony BDP-S590 issues.
Re: [SOLVED]Sony BDP-S590 - 2012 US Models ONLY
Thanks for this, I'll update it in the next release :)
tmeader
Post by tmeader »
This is very close to correct, but there's still issues with AVI files with this config. It's needlessly transcoding them into MP4 when they are XVID (and the 590's can natively play xvid fine as long as the MIME is set to "video/x-divx").
I previously mentioned this in one of the release notes threads, but I guess it was totally overlooked.
Anyhow, the correct line for AVI should be:
Supported = f:avi|divx v:divx|mp4 a:ac3|lpcm|mpa|mp3 m:video/x-divx
Thanks.
tmeader, if you look at the renderer config included in 2.6.1 you will see your suggestion there at the bottom, it is commented out because it causes incompatibility issues on some Sony BDPs. The options we have included are to my knowledge the best way to make it work on all Sony BDPs.
tmeader
Post by tmeader »
SubJunk wrote:tmeader, if you look at the renderer config included in 2.6.1 you will see your suggestion there at the bottom, it is commented out because it causes incompatibility issues on some Sony BDPs. The options we have included are to my knowledge the best way to make it work on all Sony BDPs.
My apologies, don't know how I missed that :(
Thanks.
