UMS stops working after 17 mins
I used last 2 versions of UMS with no problem (almost no problem, I still have to understand how to force UMS to transcode some movies that my tv samsung EH6030 is not able to load), now after about 17 minutes of play it stops.
I'm using windows 10 x64 with k mega codecs, java x64 1.8-91, UMS 6.3.1 java8. It never happened with previous versions (always using x64 java on pc).
Log reports:
DEBUG 2016-05-22 18:00:23.231 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2016-05-22 18:00:31.498 [New I/O worker #11] Connection error: java.io.IOException: Connessione in corso interrotta forzatamente dall'host remoto
*** (translation: opened coonections forcedly interrupted by remote host)
DEBUG 2016-05-22 18:00:31.498 [New I/O worker #11] Premature end, stopping...
DEBUG 2016-05-22 18:00:35.498 [StopPlaying Event] Matched media renderer "[TV]UE40EH6030" based on address /192.168.0.201
INFO 2016-05-22 18:00:35.498 [StopPlaying Event] Stopped playing Gli inaffidabili.avi on your [TV]UE40EH6030
DEBUG 2016-05-22 18:00:35.498 [StopPlaying Event] The full filename of which is: E:\Films\Gli inaffidabili.avi and the address of the renderer is: 192.168.0.201
DEBUG 2016-05-22 18:00:35.498 [StopPlaying Event] Resume stop. This segment 1190976 new time 2221788
INFO 2016-05-22 18:00:35.498 [StopPlaying Event] Checking shared folder: E:\Films
INFO 2016-05-22 18:00:35.498 [StopPlaying Event] Gli inaffidabili.avi marked as fully played
DEBUG 2016-05-22 18:00:35.498 [StopPlaying Event] adding "Gli inaffidabili" to playlist "Riprodotti di recente"
DEBUG 2016-05-22 18:00:39.217 [cling-349] [TV]UE40EH6030 is now offline.
DEBUG 2016-05-22 18:00:39.858 [UPNP-[TV]UE40EH6030] Action failed: Error: Current state of service prevents invoking that action. Non-recoverable remote execution failure: 400 Bad Request. (HTTP response was: 400 Bad Request)
DEBUG 2016-05-22 18:00:53.796 [UPNP-AliveMessageSender] Sending ALIVE...
and then I can only switch off tv to use UMS. It never happened with past release and with allshareplay.
Why? do I have to try installing UMS 6.3.1 java7? I changed web_port using 9009 (default: 9001) because it was used by another program.
Log reports:
Re: UMS stops working after 17 mins
same here (19minutes), from win7, playing on PS4.
tried to update java now in java build 1.8.0_91-b14
seeems related to UMS 6.3.1
ttell me if I can help with some logs.
Thx
Thx
right, man, I just rolled back to UMS 6.3.0 and after 39 minutes it's still working. The problem is related to the last 2 versions of UMS, 6.3.1 and 6.3.1.1
What was changed in this versions? I'll wait for next upgrade.
Hey guys, please try this version and let me know if it fixes this issue:
http://www.universalmediaserver.com/upl ... e85dbc.exe
I can confirm this version works perfectly the current version on the website 6.3.1.1 would stop playing at around 17-20 mins and I would have to restart the ps4 app to get UMS to show again and continue what I was watching.SubJunk wrote:Hey guys, please try this version and let me know if it fixes this issue:
With this version I managed to watch a full episode of supernatural without any issues at all.
Good SubJunk, it worls also for me. After 1h20mins it was still playing.
