UMS doesn't launch anymore on my Mac
- Optimus_prime
Re: UMS doesn't launch anymore on my Mac
Tanaytopac, I haven't had any issues with any version. I progressively updated my OS-X 10.8.2 to the 10.8.4 version, then the apple java 2013-004 update, then the java 7 JDK Update 25. Everytime i updated something (like java or OS-X) i tested both java 6 and 7 versions of UMS, and they launched with no issues. Not sure what your problem is, do you know what you did that may have caused your issue? If it's a java issue i'm not seeing it but you could try rolling back your java version, this may help in doing that http://support.apple.com/kb/ht5559
That also did not help
It looks I need to setup a fresh new OSX
