Set up instructions
xcglkjsg5twp3oj
Re: Set up instructions
Post by xcglkjsg5twp3oj »
Those instructions weren't helpful at all, to be honest. This program has been an absolute disappointment when it comes to ease of use.
I want to cast media from my PC to my PS3. My PS3 is detected, but every time I double-click on my PS3 I get the following window:
Then, when I click on SonyPlaystation3conf I get the following window:
Which program opens those conf files?
How do I get this working?
I don't know what you're trying to do, why do you doubleclick "SonyPlaystation3conf"? I assume, like Windows, that it means that you want to edit the file, and thus you must tell Windows which editor you want to use.
That isn't necessary to use UMS from your PS3 though. Instead, enter the "audio" or "video" menu in the PS3, and you should find UMS. From there, you can browse and play your shared content. The UMS GUI is just meant for configuring UMS, you don't play media from there. You do that from the playback device.
xcglkjsg5twp3oj
Nadahar wrote: Mon May 24, 2021 5:19 am I don't know what you're trying to do, why do you doubleclick "SonyPlaystation3conf"? I assume, like Windows, that it means that you want to edit the file, and thus you must tell Windows which editor you want to use.
Thanks, I had to search for a while until I figured that out. There is no quick start guide for this, unfortunately. You have to google like crazy to find that out.
If you know what UPnP AV/DLNA is, it's implied. It's not easy to make a guide for this, as the way you navigate a server varies wildly from renderer to renderer. I do agree that it should be made very clear that you're supposed to navigate your media from the renderer, not via UMS' GUI though.
