Version 6.7.3 released
mykee
Re: Version 6.7.3 released
Post by mykee »
Here is my log for folder sort problem:
https://1drv.ms/u/s!Ar9GB-v89284znwR44zYr3W5gmPz
and steps:
- Used ABC sorting, and set to Latest first
- server restarted, and this ok on my TV
- set sort option back to ABC mode
- server restarted, but nothing happened... :shock:
Regarding the problem with thumbnails on Samsung TVs (and possibly others), I've made a fix that I would appreciate if someone would test and report back. The fix for Windows can be downloaded here. If anybody needs to test this on a different platform, let me know and I'll upload a version for that OS.
mykee
Post by mykee »
Ok, this new snapshot has been fixed video thumbnails, I tested. But folder and file sort problem not. :( I waiting for a newest build. :)
erick diangilis
Post by erick diangilis »
i'm using java 8 update 152 b05 early access release with 64 bits and it's working fine here on the Windows 10 on this new ums version 6.7.3. ;)
mykee
Post by mykee »
I have java 8 build 144 (latest stable) not working, if I change sort option from/to ABC or latest modified... With 6.7.2 version was no problem...
Sami32
Post by Sami32 »
@mykee Could you try this build and report back if it solved your issue ?
https://we.tl/6VM5r1XagZ (link valid for 7 days)
Your feedback is very important to us, also if it work, so your log will be appreciate 8-)
Thank you for your understanding.
@mykee When you say that you restart the server, are you restarting UMS or are you pushing the "restart server" button?
erick diangilis
hi mykee maybe you should try the java version i'm using now at least for while cause i've been with 152 b05 with a few versions of the ums and every single one them Works without a problem or disconnection. ;)
erick diangilis
i've tried this 6.7.4 snapshot Works pretty good and very stable i think have a potential for a new release thanks a lot for this great build. ;)
pipin
Post by pipin »
Nadahar wrote: Sun Sep 03, 2017 12:04 am Regarding the problem with thumbnails on Samsung TVs (and possibly others), I've made a fix that I would appreciate if someone would test and report back. The fix for Windows can be downloaded here. If anybody needs to test this on a different platform, let me know and I'll upload a version for that OS.
Thanks. Thumbnails are working again.
Regards,
Jens
