Trying to refigure out subtitles settings I had
crimson30
Re: Trying to refigure out subtitles settings I had
Post by crimson30 »
Sami32 wrote: Sun Nov 05, 2017 11:25 am @crimson30 Part of your issue come from that you didn't read our Wiki. Click on the green link into my signature and read it carefully.
You are using the default settings that disable subtitles for english, and that is your case.
I did read it. I read it again and I still can't get it to work.
If you're referring to the language priority settings, I've tried various settings, to include eng for the Subtitles language priority and *,eng;*,und for the Audio/subtitle language priority and that doesn't work.
Note that if *,* and leaving it blank are not correct for the Subtitles language priority (to always display subtitles), this FAQ should be changed: http://www.universalmediaserver.com/faq/#Video3
Sami32
Post by Sami32 »
@crimson30
Good, so you will need to post a new log with the correct parameters that you have set now, as it was not the case in your precedent log, that we can look at your issue.
crimson30
Post by crimson30 »
I've attached the results leaving Subtitles language priority blank and setting Audio/subtitle language priority to *,eng;*,und
UMS.conf
(54.3 KiB) Downloaded 584 times
debug.zip
(854.18 KiB) Downloaded 603 times
Sami32
Post by Sami32 »
LOL
TRACE 2017-11-09 11:21:48.723 [HTTPv2 Request Worker 4] Searching for a match for: en with eng and off
TRACE 2017-11-09 11:21:48.723 [HTTPv2 Request Worker 4] Disabled the subtitles: id: 0, type: UNKNOWN, lang: off
You have edited your UMS.conf, but leaved the line commented so...no effect.
# audio_subtitles_languages = *,eng;*,und
Why don't you simply do it from the GUI's Transcoding Settings subtitles sub tab ?
@Sami Because he's running UMS headless.
crimson30
Post by crimson30 »
Sami32 wrote: Fri Nov 10, 2017 6:57 am You have edited your UMS.conf, but leaved the line commented so...no effect.
Doh. That was it. :oops:
Those sneaky octothorpes.
crimson30
Post by crimson30 »
Also, for anyone reading this in the future, please note that I ran into a problem using *,eng;*,und (subtitles wouldn't play) and had better luck using *,*
