Problem with unwanted transcoding
Re: Problem with unwanted transcoding
@squadjot can you give this https://drive.google.com/open?id=1hEwH3 ... FriqyL3LDw jar a try?squadjot wrote: ↑Fri Jun 15, 2018 8:38 pm The reason there's alot of transocding options, is because i've been trying alot..
The closest i came to playing transcoded file was this: https://www.youtube.com/watch?v=URyq8Ug2boY
Starts, but then restarts and the sound is async
As mentioned i kinda gave up, but if you have some specific tests you want me to do, i'll do it for the sake of the communitaeh![]()
You bet, i'll get back to you when i have had the time to test.atamariya wrote: ↑Mon Jun 18, 2018 11:08 pm@squadjot can you give this https://drive.google.com/open?id=1hEwH3 ... FriqyL3LDw jar a try?squadjot wrote: ↑Fri Jun 15, 2018 8:38 pm The reason there's alot of transocding options, is because i've been trying alot..
@atamariya Did you wan't me to rename and replace it with ums.jar ?
If so; then i get this errror;
A JNI error has occurred, please check your installation and try again.
I usually build a small JAR containing only UMS code without dependencies. That's the one I provided and it failed. Sorry about that. Try this one https://drive.google.com/open?id=1dGErd ... CvI6wuTZ4wsquadjot wrote: ↑Tue Jun 19, 2018 6:02 am @atamariya Did you wan't me to rename and replace it with ums.jar ?
If so; then i get this errror;Code: Select all
I'm sorry, but UMS won't start when i use your jar.
I can see javaw.exe launches.. but i never see GUI and cannot see server on TV's
Let me know if you want me to try something else.
I don't think it even creates one..Where exactly would this log be located .
Can you try running at command line?
java -jar ums.jar
Ok, the program could not start because of some old database version in "C:\ProgramData\UMS\database" so i deleted those files and got a bit further.
The GUI still doesent launch if i try to start UMS.exe
I tried to run the jar file by commandline as you suggested, i've attached the output for you.
I can see "Universal Media Server" on my TV, but there's no folders available. (and i've shared W:\Test which contains one file)
custom.log
- (49.51 KiB) Downloaded 587 times
Looks like your Samsung sends a request before the server has successfully initialized. Since there's no response from the server at this instant, there's no further attempt from the TV. Can you switch on the TV after the server has initialized? You can check if the server is up by hitting http://192.168.1.133:9001 . Also verify that the test folder lists content in the UI.squadjot wrote: ↑Sun Jun 24, 2018 8:48 am Ok, the program could not start because of some old database version in "C:\ProgramData\UMS\database" so i deleted those files and got a bit further.
BTW your debug log is located at C:\ProgramData\UMS\debug.log . You can send me that file for future results.
