Version 7.5.0 released
Re: Version 7.5.0 released
@boss
To figure out if this is a bug in DMS or something that has happened when the code was copied to UMS, it would be nice if you'd check if you have the same issue with DMS: https://transfer.sh/6MEy8/DMS-distribution.tar.gz
@Nadahar
The version you posted finds the path without manually putting it into the conf file.
INFO 2018-10-15 21:42:37.400 [main] Transcoding engine "FFmpeg Audio" is available
INFO 2018-10-15 21:42:37.509 [main] Transcoding engine "MEncoder Video" is available
INFO 2018-10-15 21:42:37.510 [main] Transcoding engine "FFmpeg Video" is available
WARN 2018-10-15 21:42:37.512 [main] Transcoding engine "VLC Video" is not available
INFO 2018-10-15 21:42:37.513 [main] Transcoding engine "FFmpeg Web Video" is available
INFO 2018-10-15 21:42:37.513 [main] Transcoding engine "MEncoder Web Video" is available
WARN 2018-10-15 21:42:37.514 [main] Transcoding engine "VLC Web Video" is not available
INFO 2018-10-15 21:42:37.617 [main] Transcoding engine "tsMuxeR Video" is available
INFO 2018-10-15 21:42:37.618 [main] Transcoding engine "tsMuxeR Audio" is available
WARN 2018-10-15 21:42:37.619 [main] Transcoding engine "VLC Web Audio (Legacy)" is not available
WARN 2018-10-15 21:42:37.619 [main] Transcoding engine "VLC Web Video (Legacy)" is not available
INFO 2018-10-15 21:42:37.650 [main] Transcoding engine "DCRaw" is available
Cheers
Cheers
@boss Thanks, that's what I wanted to hear
Now we know where the bug was introduced at least.
@Nadahar
VLC is not on my server in case you were wondering.
Cheers
Cheers
Well 7.4.0 didn't find the 7.5.0 update.. i don't know if 7.5.0 will find 7.5.1 ..yet
Thanks for the testing, boss. I'll look into it. Can you please send me the full logs?
@Subjunk
Do you mean the full log for V7.5.0
If so, with the path in UMS.conf or without the path in UMS.conf
And in TRACE mode or NOT in TRACE mode.
Cheers
Cheers
Hi, everyone.
I have the same problem like boss. But editing UMS.conf and putting the paths of mencoder and dcraw didn't help.
Instead, I copied mencoder file and dcraw file from /usr/bin/ to ums-7.5.0 folder, restart UMS and problem was solved (09:50:59 INFO Registering transcoding engine: MEncoder).
