new ums 3.0 final doesn't detect my ps3
Re: new ums 3.0 final don't detect my ps3
No solution? welcome back 2.6.5 then.
from the same computer that your hosting UMS from, can you PING your PS3?
I want to rule out a network issue from that PC (UMS HOST) to PS3
Universal Media Server Wiki!
Can you try the 3.0.0 alpha and beta versions? Then we can see when the bug first appeared. You will need to clean install each time
i've done the test and the problem started with version alpha1 for me.
I might need you to try a few versions while I narrow it down if that's ok.
Does this one connect?
No this one doesn't connect.SubJunk wrote:I might need you to try a few versions while I narrow it down if that's ok.
