Sony R550A
djrobinn
Re: Sony R550A
Post by djrobinn »
DeFlanko wrote:all conf files resides in the renderers folder in the install folder of ums.
Sent from my SGH-T999 Using ForumTouch for Android
Thanks... done!
And how do I re-run the setup wizard where it asked me questions like Wired, Wireless, etc. I need to reconfigure that... is there a manual/ cheat sheet for these basic things?
DeFlanko
Contact:
Re: Sony R550A
Post by DeFlanko »
nope you dont have to reinstall.
just restart UMS.
Go to the renderers button and make sure your custom renderer is checked.
Re: Sony R550A
Thanks... done!
To run the wizard again, set run_wizard to true in UMS.conf. The manual / cheat sheet is UMS.conf :)
Mensa_dventure
Re: Sony R550A
Post by Mensa_dventure »
Hello sukh77 and thanks for your BraviaR file. It solved 90% of my problems with the same TV.
However, I am not able to play MKV files with DTS audio. Video plays fine but, I get the "Audio Not Supported" error you had. You indicated that you fixed the problem somehow. Do you have further instructions?
I have played around with the configuration like disabling "Keep DTS Tracks." That does not make any difference.
Any advice is welcome.
