Sony KDL-32WD751 not finding UMS when wired
boss
Re: Sony KDL-32WD751 not finding UMS when wired
Post by boss »
Did you try this (If your model has it).
DLNA Certified™ media server is inaccessible
although it is listed under [Media] in the
Home Menu
 Check your LAN cable/connection or your server
connections. The TV may have lost connection
with the server.
 Perform [Media Server Troubleshooting] to check
if your media server is properly communicating
with the TV. Press HOME, then select [Settings] [Preferences] [Setup] [Network] [Home Network Setup] [Media Server Troubleshooting].
