[Solved] UMS 3.2.0 FLAC files showing as Unsupported Data
mookieguy
Re: UMS 3.2.0 FLAC files showing as Unsupported Data on PS3
Post by mookieguy »
Oy ok do you happen to have a link to the old subjunk builds of PMS? That's the last time I remember [audio high fidelity] working.
mookieguy
Post by mookieguy »
Ok I found them:
1.21.0-SB22 - plays 24 bit flac under video
Traces tab shows:
[New I/O server worker #1-4] TRACE 11:45:38.218 Starting transcode/remux of A2 - Keep The Car Running.flac
1.21.2-SB23 - does not play (This content cannot be played. (800288E1))
Traces tab shows:
[New I/O server worker #1-3] INFO 11:49:00.302 Starting transcode/remux of A2 - Keep The Car Running.flac
[win32/ffmpeg.exe] INFO 11:49:00.616 Process C:\Program Files (x86)\PS3 Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occurred... check the log file
1.21.2-SB24 - does not play (This content cannot be played. (800288E1))
1.21.2-SB25 - does not play (This content cannot be played. (800288E1))
Don't know why SB23 was trying to access ffmpeg when it should only be using audio high fidelity.
Log files attached.
debug-logs.zip
(30.23 KiB) Downloaded 460 times
I think it's fixed now. Please try this version
mookieguy
Post by mookieguy »
Excellent! This appears to be working well for me now. Thanks so much SJ!
Great! Thanks for your help too :)
Locked
