Can't open UMS because it's from an unidentified developer
ciarals
Re: Can't open UMS because it's from an unidentified develop
Post by ciarals »
For sure I'll do it :) Now I can't because the version installed is unlocked. When a new version will be out I'll surely make some screenshots (in italian :D)
Optimus_prime
Post by Optimus_prime »
Hopefully i'll have it signed in the next version for you and the UMS Userbase, Ciarals :)
ciarals
Post by ciarals »
:mrgreen: :ugeek: Yay!
Thanks a lot for reporting this :)
ciarals
Post by ciarals »
You're welcome ;)
Optimus_prime
ciarals, there was an issue with this build, 3.2.0, getting it signed correctly. You will get the same issue as before but i'm trying to fix it now and i'll put a new build up shortly (i'll prefix it with the words "Signed')
Edit: I had a look at this and as UMS is Open Source and Free to use by anyone, Plus i do all the OS-X builds and i don't even use the platform, i can't see the cost to benefit of buying a (or "join") Apple Developer Program so as to join the Mac Developer to be able to Sign all OS-X Builds with a valid Developer ID Certificate. Unless all the guys who use OS-X want to donate to obtain the $99 per year, I'm sorry but i've outlaid enough to keep the builds going (buying and setting up my Hackintosh). Don't take this the wrong way, but i can't see the benefit for me in purchasing it.
cyberbooster
Post by cyberbooster »
Where can we donate?
Optimus_prime
In the FAQ there's a donate button http://www.universalmediaserver.com/faq/ and put down what for (or if you can't just pm Subjunk after you donate and we'll sort it out). For example "OS-X App Signing"
Yup good idea :)
ciarals
Post by ciarals »
Optimus_prime wrote:ciarals, there was an issue with this build, 3.2.0, getting it signed correctly. You will get the same issue as before but i'm trying to fix it now and i'll put a new build up shortly (i'll prefix it with the words "Signed')
That's ok, you're totally right :) Mine was always and advice of course, so no problem for it. I/we will continue unlocking the app: it's surely not a problem :) Thanks for the time you've spent on this :)
