[Solved] Movies won't play anymore after upgrade to 9.5.0
Re: Movies won't play anymore after upgrade to 9.5.0
Great, thanks. That file is at https://www.universalmediaserver.com/up ... Ratios.exe
It will do a longer-than-usual file scan at first because it needs to regenerate some values in your local database
No problem, I should have checked the logs sorry. I'm making a lot of test builds in a row today :) GIve me a min
Great, thanks. It will be merged soon, either in the next release or next next one
