UMS on Samsung Smart TV (CU7000)
Re: UMS on Samsung Smart TV (CU7000)
Could you post your logs as that one error message is not helpful on its own. See the section in red above.
riffster
Post by riffster »
I'm still having issues with lots of UHD movies...i haven't followed up in a while as i encountered so unfortunate things in life ......but here i am, i have tried almost all the renderers and most will not work for my tv right now very few files are playing.....may i also point out i have two tvs and when i partially got through with the renderer for one it messes up the setting for the other
Could you post new logs with these problems?
riffster
Post by riffster »
These are my logs No UHD movies can be played file size and type appear incorrectly.please assist
ums_dbg_2024-05-06-10-47.zip
(3.53 MiB) Downloaded 308 times
For some reason UMS is not making matches anymore with that conf I made and was falling back to the old NotCD conf.
I did see a small error that may have been a factor but I also another change which makes it slightly less strict but there should not be any other devices that will match.
Samsung-Crystal_UHD_2023.conf
(9.57 KiB) Downloaded 384 times
riffster
Post by riffster »
The new config file has helped a few to play and some are still not playing..these are the new logs generated. I sent some screen shots to show whats happening when i try to play the files and how they appear on my screen. Thank You
ums_dbg_2024-05-09-15-13.zip
(4.38 MiB) Downloaded 266 times
Error Screenshots.rar
(812.76 KiB) Downloaded 457 times
The screenshots look normal. Those videos that are showing as 0.00B are those that will be transcoded as they are not supported on that TV.
To check if these videos are actually able to play properly then try playing from the #--TRANSCODE--# folder and choose "No transcoding"
Quite a few videos have DTS audio but Samsung has stopped supporting this for years so if they play at all they will have no sound if streamed.
Some use the TrueHD audio codec which is also not listed as supported.
Some use the divx codec which is not something listed as supported either but as AVI files are it is possible that it is included in with them.
If so I can tweak the conf so these are streamed.
There are some that would have been streamed but their bitrate is higher than the measured speed of your network which is rounded down to the nearest Mb/S
Renderer Samsung CU7000 75 has an estimated network speed of 25.762093156498675 Mb/s
File "Alita.Battle.Angel.2019.4K.HDR.2160p.mkv" will not be streamed because the bitrate (25053573 b/s) is too high (25000000 b/s).
Final verdict: "Alita.Battle.Angel.2019.4K.HDR.2160p.mkv" will be transcoded with engine "FFmpeg Video" with mime type "video/x-matroska"
File "I Am Legend 2007 2160p 4K UltraHD BluRay x265 HEVC 10 Bits Multi TrueHD 5.1 -Zeus.mkv" will not be streamed because the bitrate (30594011 b/s) is too high (25000000 b/s).
Final verdict: "I Am Legend 2007 2160p 4K UltraHD BluRay x265 HEVC 10 Bits Multi TrueHD 5.1 -Zeus.mkv" will be transcoded with engine "FFmpeg Video" with mime type "video/x-matroska"
See if there is anything to improve the speed like using a wired connection to the TV. If these play fine with no transcoding then the speed test may not be accurate and you can turn off the automatic bitrate setting and leave Maximum bandwidth set on 90.
All these should still play by transcoding but the setting may not be right. I have made 2 options for you to try. One tweaks the existing profile so it should work but transcoding has it downsides like being unable to seek on some devices and I think this this applies to all Samsungs, and you won't be able to turn on or change subs once it has started to play unless you restart the video.
The second conf uses the HLS profile which I think is supported on newer Samsungs but not sure. It should not have all the negatives of normal transcoding if it works and allow normal seeking and be able to change subs and audio track anytime.
Try them one at a time as they have the same priority so you don't know which one will be chosen. Delete any of the previous confs I made too.
(9.57 KiB) Downloaded 215 times
Samsung-Crystal_UHD_2023_(HLS).conf
(9.61 KiB) Downloaded 473 times
riffster
Post by riffster »
Update:_ The first config file did enable a few more file to be playable with the right information shown
the second config (HLS) cause some the playable one to become unplayable also it made a few of the unplayable ones to become playable
Is there a way to integrate both into one file?
Where transcoding is concerned the folder is always present but none of the files inside appear as playable, more so even when an attempt is made on any it show up as as the regular "stop or skip"
Please let me know if you need logs with both settings.
The HLS one should not stop any that were previously playable being not able to be played as it does not change the supported formats.
All I can think of is the speed tests were different between restarts so is choosing to transcode those that were previously streamed due to a lower measured network speed. See if you can improve this first or turn off automatic max bitrate, but this may cause videos to stutter and fail if your network speed is actually correct and the TV cannot receive data fast enough.
I don't have any devices that support HLS so it is not something I can check myself, but the web player does use HLS and it works for the most part but struggles a bit on my old computer with 1080p videos as it is not really up to the task due to the extra overhead needed. You should not have this problem with your system though but may be a problem for 4K which takes a lot of processing power to transcode. You could enable GPU encoding in transcoding settings to off-load this to the graphics card if you have a decent one. I don't have one so I can't be much help to set it up.
The #--TRANSCODING--# folder gives the option of using other transcoding engines or to select the specific sub/audio track to be burnt in to the video when playing. These should work if the settings are correct but may take some experimentation to find the right ones, and is not something I can do from here. Have a look at the DefaultRenderer.conf for what they do. The main ones to try is SeekByTime, TranscodedVideoFileSize, and ChunkedTransfer.
This should not apply to the HLS one though but not sure.
If a video does not play with the "no transcoding" option then this confirms that format is not supported on the TV and has to be transcoded to be playable.
