ALL Files Show As MPEG After Update to 3.4.0 - NOT 3.3.0
- AYColumbia
- AYColumbia
Re: ALL Files Show As MPEG After Update to 3.4.0 - NOT 3.3.0
Both versions have the bug.SubJunk wrote:Great, thanks a lot for testing itI've uploaded two more versions to help narrow it down if you don't mind
I don't need logs for these unless one has the bug
http://www.spirton.com/uploads/UMS/UMS-63eb40a.exe
http://www.spirton.com/uploads/UMS/UMS-d32cc6b.exe
OK great. We are just narrowing it down still so I know what caused the problem. Unfortunately when I can't reproduce a bug it takes a little guesswork to identify it
How about these two?
http://www.spirton.com/uploads/UMS/UMS-5a93629.exe
http://www.spirton.com/uploads/UMS/UMS-5d7e1e7.exe
- AYColumbia
Good news as both of these worked.SubJunk wrote:OK great. We are just narrowing it down still so I know what caused the problem. Unfortunately when I can't reproduce a bug it takes a little guesswork to identify itHow about these two?
I noticed something that is also in 3.3.0. I rarely use the MP4 container as I prefer MKV, but I do have a couple videos in MP4 (avc+aac) and those show the MPEG icon and no time/resolution info per the submitted bug images. I re-muxed the MP4s into MKVs and they work just fine. Not sure if you want me to create a new ticket for this or not so let me know.
OK cool. I have hopefully identified the cause of the bug but now let's make sure, hopefully there will just be 3 more versions to test - these two and one afterwards:AYColumbia wrote:Good news as both of these worked.
http://www.spirton.com/uploads/UMS/UMS-0c8b0b2.exe
http://www.spirton.com/uploads/UMS/UMS-adb17d0.exe
Do the videos play?AYColumbia wrote:I noticed something that is also in 3.3.0. I rarely use the MP4 container as I prefer MKV, but I do have a couple videos in MP4 (avc+aac) and those show the MPEG icon and no time/resolution info per the submitted bug images. I re-muxed the MP4s into MKVs and they work just fine. Not sure if you want me to create a new ticket for this or not so let me know.
- AYColumbia
Both builds "quasi" worked. In one folder, all the files showed the MPEG icon but they did play. The other folder showed the proper icons. I PMed the log file location.SubJunk wrote:OK cool. I have hopefully identified the cause of the bug but now let's make sure, hopefully there will just be 3 more versions to test - these two and one afterwards:AYColumbia wrote:Good news as both of these worked.
I'm not sure if the following info is helpful or not but the folder with the MPEG icons has 3 types of extensions: m2ts, ts and mkv. The files with mpeg2 video are the m2ts, ts and one mkv file and the very first file is the mpeg2 file (m2ts). The second folder has files with avi, mkv, divx and ts extensions. It's a mix of avc, mpeg4 and mpeg2 encodes. Note that the divx files have an avi icon on them.
Yes, the videos play.SubJunk wrote:Do the videos play?AYColumbia wrote:I noticed something that is also in 3.3.0. I rarely use the MP4 container as I prefer MKV, but I do have a couple videos in MP4 (avc+aac) and those show the MPEG icon and no time/resolution info per the submitted bug images. I re-muxed the MP4s into MKVs and they work just fine. Not sure if you want me to create a new ticket for this or not so let me know.
Hmm OK, hopefully this one has the bug?AYColumbia wrote:Both builds "quasi" worked. In one folder, all the files showed the MPEG icon but they did play. The other folder showed the proper icons. I PMed the log file location.SubJunk wrote:OK cool. I have hopefully identified the cause of the bug but now let's make sure, hopefully there will just be 3 more versions to test - these two and one afterwards:AYColumbia wrote:Good news as both of these worked.
http://www.spirton.com/uploads/UMS/UMS-81800cc.exe
OK cool. Is there a past version that showed the info for MP4s or was it always like that?AYColumbia wrote:Yes, the videos play.SubJunk wrote:Do the videos play?AYColumbia wrote:I noticed something that is also in 3.3.0. I rarely use the MP4 container as I prefer MKV, but I do have a couple videos in MP4 (avc+aac) and those show the MPEG icon and no time/resolution info per the submitted bug images. I re-muxed the MP4s into MKVs and they work just fine. Not sure if you want me to create a new ticket for this or not so let me know.
- AYColumbia
It does have the bug. Both folders show the MPEG icon and 0s for time/resolution. However, all the files did play. Log is out there for you.SubJunk wrote:Hmm OK, hopefully this one has the bug?
You know, I think it has always shown MP4s this way but because I rarely use MP4s I can't be absolutely sure. I would guess it's always been this way. I've already remuxed my MP4s into MKVs anyway.SubJunk wrote:OK cool. Is there a past version that showed the info for MP4s or was it always like that?
- AYColumbia
In the words of Austin Powers...Yeah, baby! Yeah!SubJunk wrote:OK great. How about this one?
http://www.spirton.com/uploads/UMS/UMS-AYColumbia.exe
BTW, if you want me to work on the MP4s thing with you, just let me know. I produce those with Sony Movie Studio which I normally then remux to MKVs, but if you want to work on fixing those too, I can help.
