GitHub attachments
- Optimus_prime
Re: GitHub attachments
Debug related to PR #340 4.1.0
Video's always Transcoding even if they play native to the renderer
- ums_dbg_4.1.0.zip
- (47.88 KiB) Downloaded 2988 times
- Optimus_prime
Attachment for issue # 385
- ums_dbg_Whitelist_issue.zip
- (23.42 KiB) Downloaded 2933 times
https://github.com/UniversalMediaServer ... issues/384
skeptical commented a day ago
@wikipuka is UMS recognizing the BDV-E2100 correctly? Looks like there was a recent firmware update which may have changed something. Post TRACE logs in the GitHub attachments thread if it's being misrecognized.
Debug logs related to PR 5.0.0 #362
Debug log related to PR 5.0.0 #362
@leroy: put the enclosed update.jar in your UMS 5 program folder, restart and see if it fixes the issue: (and remember to remove it later onleroy wrote:Debug log related to PR 5.0.0 #362
issue: supported video files are transcoded with de GUI bumb / WEB bumb play feature.
issue: Video with internal subtitle is transcoded as it should, but the subtitle is not used with the GUI play feature.
issue: The log mentioned that the video is stopped on "on your unknown renderer" while it was started on my TV.
