problems with ums and smart tv
Re: problems with ums and smart tv
The only difference I have compared to your screenshots is I only have 4 CPU threads and UMS reports that it seems I have 4. Everything else is identical.
Can you re-upload the Log files (out from dropbox and into the forum attach file system -- dropbox is blocked at work lol)
Universal Media Server Wiki!
I tried to attach the zip file but the same thing happened as before. (kicked out to the sign in screen and doesn't even upload the message). This is strange as I have been able to attach files to other forums, seed torrents etc. Any ideas how I can get this to work?
Hi! I am allso using TCL smart tv but I cant even found where the UMS is streaming. I'm allso using UMS on my PS4 and it works fine but wouldlike to use it on TV since UMS recognize it. Could i get some help from you guys. Do I need to install some app on TV to watch it?
This thread is from 2014, so I doubt the original posters are around to answer. If UMS detects your TV, the TV is probably already running UPnP AV/DLNA. To figure out how to access it, look for UPnP or DLNA in the TV user manual.
