Version 4.1.1 is released
Re: Version 4.1.1 is released
raprop wrote:Hi!!
I detect with 4.1.0 or 4.1.1 and LG TV. when try to play a mp4, the ums transcode to mpeg but in 4.0.0 is detected h264 and send to TV perfectly.
in the 4.0.0 work perfect streams the subs when add SupportedSubtitlesFormats = SUBRIP,ASS to LGLA6200. This profiles works fine with LGWebOS and LG 60" top line 2013
Thx.
Hi raprop, can you please follow the link in my signature to make logs for it? Then I can fix it
raprop
Post by raprop »
hi! attach debug from 4.0.0 and 4.1.1
http://ul.to/d2zy0rnk
http://ul.to/g8orwiut
sma76928
Post by sma76928 »
Hi: I have an LG 47LB6500 ith webos and neither 4.1.1 or 4.0.0 are working. When transcoding, the image goes in slow motion. also the transcode gets to the TV as MPG2 and without audio
let me know if i can provide with more information in order to fix the transcoding problem
here is the link to the debug file
https://drive.google.com/file/d/0B1YgMb ... sp=sharing
best regards
radwizard
Post by radwizard »
I'm sorry if this has been covered somewhere else, but is there support in this version for the Wii U?
INAX93
Post by INAX93 »
Hi all !
First of all I want to thank you for the fantastic work you do since few years...
I'm from France and using UMS from its very beginning.
Came back from vacation and just installed the new 4.1.1 ( from the last 3... version ).
I just tested the Web interface, and i was waiting for this feature since the beginning. (not really for the local network use but its a feature that can help me see my series from the internet when i'm not home... I have a high speed connection home 1Gb/s optical fiber so i can download remotely to home and watch the streaming from an hotel for example... and this is very cool ! )
But, i have few questions i'll try to separate them, this way it will be easier for you to understand what i'm asking i think... so :
- On the web interface, will you later add a login/password feature ? ( this way I and the ppl i want will be the only ones to have access and not all the internet)
- On the web interface, I have seen that you are working to get HTML5 working well and this is great, but when using the Flash player on Google Chrome for exemple, when i try to start my serie and bypass the first few minutes it does not work, I cannot select the time. the point is, what if I loose internet connection or close the browser (or crash), do i need to start from the beginning ? or is there something to do in setup to allow "moving" in the movie ?
- On the web interface again, if I try to use the blue arrow under the serie I start (written download) it just open a new window with the same streaming and don't allow me to download the video to my device... is this normal ?
That's all for me, and if i can help for anything feel free to ask... (I do not code but i'm a systems and network specialist so who knows...)
One more time thanks a lot for your work and your time !
( Sorry for the language mistakes you can find, French and Serbian are my first language, English comes third so... sorry :) )
Have all a nice day.
Regards.
Goran TOMIC
INAX93 wrote:Hi all !
Thanks for the kind words :)
INAX93 wrote:But, i have few questions i'll try to separate them, this way it will be easier for you to understand what i'm asking i think... so :
We have one already but it's disabled by default, I can't remember if we added it to UMS.conf. Will check it.
INAX93 wrote:- On the web interface, I have seen that you are working to get HTML5 working well and this is great, but when using the Flash player on Google Chrome for exemple, when i try to start my serie and bypass the first few minutes it does not work, I cannot select the time. the point is, what if I loose internet connection or close the browser (or crash), do i need to start from the beginning ? or is there something to do in setup to allow "moving" in the movie ?
Yeah it is a bit annoying that it doesn't support seeking, we will hopefully be able to add that feature soon :)
INAX93 wrote:- On the web interface again, if I try to use the blue arrow under the serie I start (written download) it just open a new window with the same streaming and don't allow me to download the video to my device... is this normal ?
I'll check that soon too :)
INAX93 wrote:That's all for me, and if i can help for anything feel free to ask... (I do not code but i'm a systems and network specialist so who knows...)
Regards.
Goran TOMIC
Your English is a lot better than my French or Serbian, merci :)
INAX93
Post by INAX93 »
Regards.
Goran TOMIC
Thanks a lot ! waiting for your feedback then ! :)
I've just seen a new thread about UMS Security that may help, but after trying the "Pin-Code" it not seems to work... i'll go add a reply on this thread :)
thanks again and have a nice day!
