[SOLVED]This content cannot be played (800288E1)
avrignaud
Re: [SOLVED]This content cannot be played (800288E1)
Post by avrignaud »
I will try 1.5.0.
Note, however, that because I was having problems I tried flattening the machine. I just wiped the boot drive, reinstalled Windows 7 professional + service pack 1, and then installed UMS 1.5.1. It asked me if I wanted to install AVISynth 2.6 (I think), which I accepted. And then I ran UMS, and did no changes other than sharing my video folder.
When I browse from the PS3, some of my Dexter shows have strange, tinny sound (but not all). More importantly, all Game of Thrones .ts files fail with the error code in this thread (800288E1).
Do you think 1.5.0 can actually fix that? Will try!
AV
avrignaud
Post by avrignaud »
I tried UMS 1.5.0, had the same issue. Then uninstalled UMS, and installed PMS 1.6 — that works for everything except the .ts files again. So I'm stumped!
Do you mean UMS 1.6.0, or PMS 1.6? I don't know if there was a PMS 1.6 release actually but it would be very old so I will assume you mean UMS, in which case I'm glad it's working, .ts files aside :)
