samsung un46eh6070 allshareresume error
Re: samsung un46eh6070 allshareresume error
Ok itried version 4.3 from front page.I completely deleted the install from previous version,including the .config files.I tried it on the renderer for eh6070..and both variations of allshare for samsung.I am attaching the 3 different debug logs.i dont know if it will show it but in the first debug which was for eh6070..i could go to the resume file and it would play for a second then would kick me completely out ofUMS tell me there was no network connection.I am now going to try the 5.o beta and keep it for awhile.Would you llike debug files from that also??May take me a few days to get back to you!?
- ums_dbg2.zip
- (92.34 KiB) Downloaded 269 times
- ums_dbg1.zip
- (50.55 KiB) Downloaded 260 times
- (41.48 KiB) Downloaded 283 times
Hi johnscrub, sorry for the late reply! It seems like you don't have MEncoder installed on your computer. You can either install it or disable its use by unticking "remux videos with tsmuxer" in the FFmpeg section of the Transcoding Settings tab
Ok i will try to get that installed and go from there,,,coulda swore i did have it but im noy positive.Thanks for all your help..and i will report back on issue!!SubJunk wrote:Hi johnscrub, sorry for the late reply! It seems like you don't have MEncoder installed on your computer. You can either install it or disable its use by unticking "remux videos with tsmuxer" in the FFmpeg section of the Transcoding Settings tab
Sorry it has taken me so long to get back to you....now have all that installed and same issues.Even if i force the appropriate renderr i will have time tonight to sit and get you a proper debug log.Thanks
Well here are some debug logs from my adventure..lol.The first one is if i let it auto find ,,second and third one are forcing allshare or samsung led tv.If i tried to play certain files with my specific tv 6070 or let it auto select it wouldnt play,but forcing allshare or samsung led would allow playback.Still have the issue of not resumiong files.If i forced 6070 then was same results as autofind so hope this is helpful but am in no way expecting you to jump right on the issues.Akll your help is appreciated!!!
Also i have gotten an xbox one for christmas self present ..hahah..i will see if i can resume files on it as i dont remember if i have tried this yet..hope all is well on your side of things.
- ums_dbg3.zip
- (39.42 KiB) Downloaded 282 times
- ums_dbg2.zip
- (29.52 KiB) Downloaded 286 times
- (81.58 KiB) Downloaded 266 times
