Xbox One no longer locating UMS
Re: Xbox One no longer locating UMS
Thx for your patience, could you please also try HTTP Engine V125233Guyver wrote:Made with UMS-764ce59.exe
Sorry for the wait.
Thx, sorry for the slo-mo long-distance debugging tedium, but could you now try this build (with and without http_engine_v2): UMS-1bbfc78.exe.
No problem, at least stuff it getting done.
I just wanted to post that I am not having any problems with UMS 5.0.1 (Java 8) and my Xbox One. Here's the debug, hopefully it might help.
- ums_dbg(Jimwhat-XboxOne-Java8).zip
- Windows 8.1
- (21.69 KiB) Downloaded 620 times
Greatjimwhat wrote: just wanted to post that I am not having any problems with UMS 5.0.1 (Java 8) and my Xbox One. Here's the debug, hopefully it might help.
It took some time, but I got it to somewhat work. I had to disable the HTTP Engine V2 though, and even then it's spotty.infidel wrote:Greatjimwhat wrote: just wanted to post that I am not having any problems with UMS 5.0.1 (Java 8) and my Xbox One. Here's the debug, hopefully it might help.! Woud it be possible for you to also send logs using the debug version: http://www.spirton.com/uploads/UMS/UMS-764ce59.exe?
Sometimes, it doesn't find the renderers, other times it doesn't show to content of the folders, and it sometimes tells me that the port is closed (its definitely open though).
Reverting back to normal 5.0.1 fixed all of these problems. Hope this helps
- ums_dbg(Jimwhat-Debug5.0.2).zip
- (45.51 KiB) Downloaded 645 times
Thx jimwhatjimwhat wrote:It took some time, but I got it to somewhat work... Sometimes, it doesn't find the renderers, other times it doesn't show to content of the folders,
I thought the same thing.infidel wrote:Thx jimwhatjimwhat wrote:It took some time, but I got it to somewhat work... Sometimes, it doesn't find the renderers, other times it doesn't show to content of the folders,. Apologies if this is a silly question, but is it possible there was another instance of ums running? The debug version isn't that different from 5.0.1, it just logs a lot more info.
I said that the debug version was spotty, and by that I mean that the only time it would work was after rebooting my computer. Running UMS for the first time after a reboot worked fine, but if I quit the program, and then re-launch it later, it wouldn't work. Checking the task manager showed that there was no UMS running, but there was and instance of Java running that I could not close (end process). The only way I could get rid of it was to reboot the computer.
So, this might have been the other instance you were talking about. Oddly enough, my current 5.0.1 doesn't do that for some reason. When I quit it, nothing remains in the Task Manager.
Example:
5.0.1
1. Run then Quit
2. Run then Quit
3. Run then Quit
4. Run then Quit
After this, Task Manager shows no UMS or Java running. When I tried the same thing in 5.02 it looked like this:
5.0.2
1. Run and Quit
2. Run and Quit
3. Run and Quit
4. Run and Quit
The Task Manager would show 4 instances of Java still running (and for some reason I can't force close them). This was most likely the cause of the problems, but I didn't know how to fix it, so I just reverted back to the normal UMS. Let me know if you have any other questions
