Audio Not Supported
Re: Audio Not Supported
We should start to solve the issue step by step. Please switch off other renderers on your net and let only the KDL-70R550A to be working, not use your custom conf and send the log. I see that there is a problem with the recognition.
Thank you for your assistance. I have shutdown everything else and am using the default file that is for a Vizo tv and when I go to the folder it freezes still.
- (77.62 KiB) Downloaded 769 times
I made a .conf for your TV. It should be updated after testing. Please try it and send the log.
Sony-BraviaR.conf
- (4.6 KiB) Downloaded 756 times
Thank you. I have added it. I had to delete the vizio tv one as it kept defaulting to that one. Now I can open the folders but the files are not listed. I just see the subs and transcode folders but not the movie files.
- (108.49 KiB) Downloaded 656 times
UMS is still using wrong renderer.conf (not recognises your TV). Please try this new. You not need to delete Vizio-SmartTV.conf you can simply select renderers at the General Configuration tab and let UMS recognize only renderers you have on the network. This minimize the false positive recognition.
Sony-BraviaR.conf
- (4.51 KiB) Downloaded 595 times
I cannot connect to the server with the last conf file. What I do see is that it loads the correct icon for a second and then it goes to the default icon. It is using the one you gave me though.
- (108.49 KiB) Downloaded 778 times
OK. Try to change the to
UpnpDetailsSearch = Sony , KDL-[0-9][0-9]R(5)[0-9][0-9]A
UpnpDetailsSearch = KDL-70R550A DAD TV
What is positive that the renderer is recognised but you made a mistake. You wrote but is must be To prevet UMS to not use the default icon please change to e.g. I prepared this conf with the icon for the next UMS release but for testing it of course doesn't work.
Here is the updated conf.
UpnpDetailsSearch = KDL-70R550A DAD TV SeekByTime = true
SeekByTime = true
Sony-BraviaR.conf
- (4.46 KiB) Downloaded 602 times
Thank you very much. I have added the file and can get back in now but still have the same issue with some files not being seen. In this sequence I went to 3 different folder and only 1 saw the file inside of it. I am getting a kick from my 5 year old each time I shut down the wireless to only test the TV goes nuts about how her tablet isnt working lol.
- (90.1 KiB) Downloaded 773 times
